intermittent tach problem
I am having problems with the tach on the milano I just bought. Most of the time, the tach indicates with a range between 500 and 2500 rpm.
Then, once in a while, I will start up the car an it will work flawlessly. It will continue to function until I shut the car down. Then, the next day, back to not working right.
Since the tach works right some of the time, I hope that I am just dealing with some kind of bad connection. I read the previous tach threads on here and as a result I checked the wires on the top of the coil. I found two white wires there that may be of interest. They didnt look like particularly bad connections or anything. There was also a ground wire present. All of these connections seemed ok.
Should I replace these connections anyway? Or does anyone have a better idea?
