Old 08-03-2006, 08:59 AM
Hit an Apex's Avatar
Hit an Apex Hit an Apex is offline
Car idling at 3,000!
I was changing my thermostat and bleeding today, and went to hit the throttle and brought it up to 3k. However, it never went back down. I changed the throttle position switch - no help. (i also sheared the bolts off that hold it in...)
I checked the aux air valve - fine. Vacuum hoses - fine. Throttle doesn't seem stuck either. I'll start it and it'll go to 2,000 for about .5 seconds, and then move on to 3,000 where it stays.
HELP
Old 08-03-2006, 09:15 AM
Sounds like you got a big air leak or stuck throttle butterfly return.
Virginia Beach, VA
sdpatchin@aroc-usa.org
Old 08-03-2006, 02:06 PM
Those two should be touching? But is that enough gap to warrant a 3,000 rpm idle?
Old 08-15-2006, 08:08 AM
Firefox's Avatar
Firefox Firefox is offline
Yes, they should touch at idle! Without load the engine needs not a lot of air to hold 3000 rpm!
Clean the throttlebody and ensure that the butterfly is shuts full at idle.
andi
Andi Messerli
The Swiss V6 Junkie
http://img390.imageshack.us/img390/4...alelogotp9.gif
Club Gruppo Radicale Basilea http://www.gruppo-radicale.ch
The Swiss Alfa Community at http://www.alfa-forum.ch
Old 08-15-2006, 09:05 AM
Car is fine now. I sware it has a mind of its own.
