#121 (permalink)
Old 08-09-2006, 12:22 AM
AR4me's Avatar
AR4me AR4me is offline
Hey Gifford,
I called Autopower on Monday. The roll cage is in production and should be ready for pick-up Aug 18. That should give me enough time to get it in by Sep 3, IF I have finished all the current stuff
Tonight I took out the driveshaft, Dedion cross-member (exposes Dedion mount), and the transaxle mounts. I will rebuild the driveshaft (hopefully tomorrow evening) and then take it out for balancing.
By Sep 3 the car should be mechanically solid - we'll see. The goal of the current maintenance like work is mostly to get a reliable car.
The car will be 155 HP with a weight of around 2400 lbs at best - still no match for the 2 liter gtvs that are easily around 2100 lbs with 170+ HP... Of course, they are probably also in a higher class. Anyway, it will be fun
Jes
87 Milano 3.7 24v - race car
  #122 (permalink)
Old 08-12-2006, 09:17 AM
AR4me's Avatar
An update:
I was planning to rebuild the driveshaft during the week and then have it ready for the weekend. Well... Don't you just hate when work gets in the way of your private life? Anyway, this morning, Saturday, I finally got an hour to finish rebuilding it. The only thing that slowed me down was the lack of a deep 32mm socket to take off the nuts holding the fork to the front half of the driveshaft at the center support. Got a hold of a 32mm deep socket and off it came. So, the driveshaft is complete and I will drop it off for balancing Monday morning. It has new couplings, center support and bearing. The old stuff actually wasn't that bad. Some cracks had started to develop, but nothing coming apart.
Below some pics of the rebuild driveshaft and the work in progress. Next item on the list is replace the Dedion bushing... Not sure I will get time this weekend - work...
Jes
  #123 (permalink)
Old 08-12-2006, 10:53 AM
La Voce's Avatar
La Voce La Voce is offline
AnsArias
Drive on! Thanks for detailing your efforts and the detailed photos, this will help all of us some day as we work on our cars.
Jim Isaacs
Harvest, AL
1988 Milano Verde
1979 Sprint Veloce
  #124 (permalink)
Old 08-12-2006, 12:44 PM
Grant's Avatar
Grant Grant is offline
I don't remember having to use a 32 to take my driveshaft out!?
1984 GTV-6 - 80K miles
  #125 (permalink)
Old 08-12-2006, 01:19 PM
AR4me's Avatar
Grant, not to take the driveshaft out, but, to take it apart to replace center bearing and support.
Jes
  #126 (permalink)
Old 08-12-2006, 01:27 PM
Grant's Avatar
Ah, good call. Where did you get your center bearing from? I was afraid they'd be NLA.
  #127 (permalink)
Old 08-12-2006, 01:52 PM
AR4me's Avatar
I used many different sources to piece together all the necessary parts for all the stuff I'm doing - this has become like a mechanical restoration of a milano... The center bearing, support, and "cups" (you can probably reuse old "cups"), may have come from Alfa Parts in Berkeley.
Jes
  #128 (permalink)
Old 08-12-2006, 02:46 PM
DaveH's Avatar
DaveH DaveH is offline
Isn't the center brg a standard SKF item? As in, it doesn't have to be an Alfa part? Or is that the wheel brgs I am thinking about?
'85 GTV6
  #129 (permalink)
Old 08-12-2006, 03:59 PM
AR4me's Avatar
...yes, I think so, but the center support is certainly an Alfa piece.
Jes
  #130 (permalink)
Old 08-12-2006, 05:32 PM
DaveH's Avatar
Ah. Must be the wheel brgs then.
Enjoying your thread Jes. Mandatory reading for me these days.
'85 GTV6
  #131 (permalink)
Old 08-12-2006, 06:05 PM
AR4me's Avatar
Dave,
What I meant was that, yes, I think the center bearing is SKF, but the center support is Alfa - sorry about the confusion.
Jes
  #132 (permalink)
Old 08-13-2006, 10:46 AM
kredden's Avatar
kredden kredden is offline
I like the drip pan under the red & blue hot rod next to your drive shaft :-).
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
  #133 (permalink)
Old 08-13-2006, 11:17 AM
AR4me's Avatar
That's when my 3.5 year old comes out to work on his car when I'm working on the milano. He has a funnel and will be changing pretend oil (=water) etc., spark plugs, wash it, ... He borrows my jack, etc.
Jes
  #134 (permalink)
Old 08-13-2006, 12:40 PM
Tomasz Tomasz is offline
Sunroof
Jes,
Thanks a lot for this perfect coverage! I'm personally at the very begining of very similar porject (presently no interior and waits for engine and gearbox to be taken out). Like yours my car also has sunroof, and like you I don't need this heavy device. My question is what are your plans toward the whole in the roof?
Best regards,
Tomek Slawinski
___________________
[COLOR="DimGray"]Alfa Romeo 164 Super 3.0 24v 1995
Alfa Romeo 75 America 3.0 1990
Alfa Romeo 75 1.8 IE 1991
Fiat Stilo 1.8 Dynamic 2002
Subaru Outback 2.5 AWD 2000[/COLOR]
  #135 (permalink)
Old 08-13-2006, 12:47 PM
AR4me's Avatar
Weld it shut. I have been considering seam welding (part of) the front - we did that on my 3.7. Though, for now, the only additional stiffness will come from the cage, which Colin and I hope to install next weekend. If I had the engine out I would definitely seam weld part of the front, e.g. the two rails from around the torsion bar rear mount and forward, the seams at the "towers" for the shock mount, as well as other places that make sense.
Jes
