#1291 (permalink)
Old 05-25-2008, 11:51 PM
Mezevenf's Avatar
Send a message via ICQ to Mezevenf Send a message via AIM to Mezevenf Send a message via MSN to Mezevenf Send a message via Yahoo to Mezevenf Send a message via Skype™ to Mezevenf
Originally Posted by 75evo View Post
You're right, just saw that. That's actually a good deal. Do you think they will allow me to get the dash 2 at a good deal? Dash3 lite seems to still be in the works.
Originally Posted by AR4me View Post
PM sent. Bernard will kill you
Jes
Haha, it's cool
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
  #1292 (permalink)
Old 05-26-2008, 06:32 AM
AR4me's Avatar
Originally Posted by BigSwede View Post
Probably not because the bundled units are paired, i.e. you can't split them up and use them with another unit...
Zamani, this shouldn't apply to our units.
Jes
87 Milano 3.7 24v - race car
  #1293 (permalink)
Old 05-26-2008, 10:26 AM
BigSwede's Avatar
Jes
It applies if they are bought as a "kit" with the lower pricetag.
Mats Strandberg
  #1294 (permalink)
Old 05-26-2008, 01:09 PM
That's OK, I've taken this to PM with AR4me.
1996 155 V6, Squadra Tuning, RJR cams
  #1295 (permalink)
Old 05-26-2008, 02:45 PM
AR4me's Avatar
Long story, but not for us due to circumstances to lengthy too explain here.
Jes
  #1296 (permalink)
Old 05-26-2008, 08:00 PM
AR4me's Avatar
Finished pulling obsolete wires out of the dash - tedious since I wanted to maintain select ARC functionality (oil level monitoring, coolant level monitoring, brake fluid pressure monitoring). I just need to remount the ECO, the fuse panel, and the electronic module for the ARC.
I also started making the new instrument cluster housing that will hold the Race-Technology Dash2. Once complete I will cover it in black felt.
Jes
  #1297 (permalink)
Old 05-26-2008, 08:12 PM
very nice
  #1298 (permalink)
Old 05-26-2008, 08:30 PM
Rookie ROX's Avatar
Urgh. Have fun with that.
Take my advice though and make sure you triple check the purpose of a wire before removing it. I learnt the hard way that not only are there two sets of wiring diagrams, they're also not 100% accurate. Make sure you test absolutely everything before bundling it back up (another terrible job) to make sure it all still works.
Apart from that, looking good
ROCK ON
R~R
  #1299 (permalink)
Old 05-26-2008, 08:42 PM
AR4me's Avatar
ROCK ON
R~R
No need to worry - have done similar things before - don't use wiring diagrams doing this kind of stuff just need EE common sense Besides, all tested and checked - wires ready to be tugged up
Jes
  #1300 (permalink)
Old 05-27-2008, 01:55 AM
Let us know which wire from the dash you're gonna hookup to the DL1 for the RPM input
  #1301 (permalink)
Old 05-27-2008, 05:01 AM
BigSwede's Avatar
The white one from the neg post on the coil will do nicely AFAIK.
Mats Strandberg
  #1302 (permalink)
Old 05-27-2008, 10:29 AM
Cool, I saw the table from race-technology on what would and wouldn't work. I would prefer to just get it off one of the wires in the dash that goes to the tacho as I want to avoid running more wires into the car. I'll double check the wiring diagrams again.
  #1303 (permalink)
Old 05-27-2008, 11:53 AM
AR4me's Avatar
If I recall correctly, the white wire in the 7 or 8 pin connector at the back of the instrument cluster is for the stock tach.
Jes
  #1304 (permalink)
Old 05-27-2008, 09:23 PM
AR4me's Avatar
Finished the new instrument cluster that will hold the DASH2 and the 4 buttons to control it (mounts just like the stock instrument cluster). Oddly the sheet for the DASH2 says the 3 mounting holes are M4, but I don't see how M4 will fit those holes - don't want to force it - they should spin in by hand.
Jes
  #1305 (permalink)
Old 05-27-2008, 10:00 PM
Looks nice Jes. Did you line the metal/aluminum with felt cloth?
How much for the buttons? Probably very expensive, but I hope it's not going to be as useless as the remote switch they sold us for the DL-1.
It seems that I can also use my own switches, but the plug which goes from the switches to the rear of the Dash2, is it included? I assume if it were included, would be a plug with loose wires/flying leads right?
