#916 (permalink)
Old 04-04-2007, 08:30 AM
AR4me's Avatar
Follow up to S-engine conversion
So, there was debate and some questioned running the 3.0 S-engine (with S crank pulley) with the 2.5 Milano flywheel. This was Larry Jr.'s recommendation and it seems he was spot on. I have observed no unusual vibration. He basically suggested to:
1. Run Milano 3.0 crank pulley with Milano 3.0 flywheel, or
2. Run S crank pulley with Milano 2.5 flywheel.
Since I wanted to run the S crank pulley (due to running Motronic - needs crank angle sensor and 60-2 ring gear...) and had all the 2.5 pieces, option 2 was an easy choice. As it turned out, it didn't cause any imbalance issues - at least nothing I can notice.
Jes
87 Milano 3.7 24v - race car
  #917 (permalink)
Old 04-07-2007, 05:21 PM
AR4me's Avatar
Looking for a few parts:
Looking for:
1. Verde side skirts, fender flares, and 3 piece spoiler
2. Milano fuel pump bracket with bolts
3. Milano fuel filter bracket
Anyone?
Jes
  #918 (permalink)
Old 04-07-2007, 06:26 PM
kredden's Avatar
There's some fender flares on e-bay, they've been up a few times with no takers, I think this is the cardisc guy (?):
http://cgi.ebay.com/ebaymotors/Alfa-...04751739QQrdZ1
Kevin
86 Spider Veloce
87 Verde
Milano registry custodian(www.alfamilano.com)
  #919 (permalink)
Old 04-07-2007, 09:12 PM
Grant's Avatar
Jes,
We're parting out a Platinum. I can send you the fuel pump/filter bracket's and bolts in exchange for storing those bilsteins for so long! PM me your addy if you want.
1984 GTV-6 - 80K miles
  #920 (permalink)
Old 04-07-2007, 09:28 PM
AR4me's Avatar
Thanks Grant!
PM on the way
Jes
  #921 (permalink)
junglejustice's Avatar
What are you doing!?
I have the brackets for you as well - let me know if the others don't work out!
  #922 (permalink)
Old 04-07-2007, 09:31 PM
AR4me's Avatar
I'm putting in my 2nd Bosch Indy fuel pump (supports 700 HP ) and 2nd fuel filter. My cell has dual pick-up and I need to put in the 2nd pump and filter - I'm using the stock Milano mounting brackets for my custom fuel pump and filter.
Jes
  #923 (permalink)
Old 04-07-2007, 11:04 PM
Crap... Better go dig them out of the trash-bin then...
  #924 (permalink)
Old 04-08-2007, 10:57 AM
Jes,
I have a set of Verde wheel wells and skirts I wouldn't mind getting rid of. I have the spoiler too - but I think I am going to hang onto that. PM me if you are interested in those bits.
Chris
'87 Milano Project
'82 Spider Veloce
  #925 (permalink)
Old 04-08-2007, 07:56 PM
AR4me's Avatar
PM'ed you.
I spent some time cleaning up Roxanne after last weekends event, and I started to make some changes.
In the mad dash to get Roxanne ready for last weekend, I did not have time to do the "cold" intake. This weekend I redid it and in the process replaced the two headlight replacements with more solid solutions. I bent some pieces in Aluminum and mounted the "funnel" on the back of the passenger side piece. I did not (yet?) put one behind the driver's side. Should I? Right now it is asymmetric... Not sure... Opinions? Originally, I did have one on the driver's side, cooling the ABS pump.
Jes
  #926 (permalink)
Old 04-08-2007, 09:09 PM
Nikoror's Avatar
Send a message via MSN to Nikoror
take some pics during the day looks pretty racy like that though... not sure if it's worth changing
[URL="www.racingowls.com"]Rice University SAE[/URL]
  #927 (permalink)
Old 04-08-2007, 10:21 PM
alfettish's Avatar
I like it that way. it's no nonsense!
  #928 (permalink)
Old 04-29-2007, 06:49 PM
AR4me's Avatar
So, been doing some maintenance to Roxanne this weekend (although next event is some time away).
I also re-located the fuel filler from the stock location so that I don't have to jack up the right rear when re-fueling I was planning on putting it on the C-pillar as shown in the last pic, but there is 3 layers of sheet metal with some welded reinforcement too close to allow the fuel filler to fit through, and I did not feel like weakening the area. So, it went in an aluminum bracket mounted in the trunk.
I plan to mount the 2nd fuel pump next to eliminate the fuel starvation out of turns with 2/3 tank left
Jes
  #929 (permalink)
Old 04-29-2007, 06:55 PM
alfettish's Avatar
That looks great.
  #930 (permalink)
Old 04-29-2007, 07:01 PM
AR4me's Avatar
Thanks.
Another big advantage of this location is the free support for the 5 gallon fuel jug when refueling. Trust me it gets heavy holding it. Now the trunk opening offers a perfect rest
Oh, and I'm pretty much set on the paint scheme and some other exterior cosmetic details - should get done in the next 2-3 months or so
Jes
