#856 (permalink)
Old 03-24-2007, 12:37 AM
AR4me's Avatar
Yeah, unfortunately that is often how it goes with custom stuff...
Ok, made some progress. Attached are some pics of the engine bay. You'll see the mounting of the 164 air-box, the plenum mounted (and the throttle body mount cut off), the coolant bottle mounted for mock-up to measure the cutting and fitting of the 180* aluminum bend for the plenum, all Motronic wiring complete (had to extend the crank angle sensor harness tail - a bit of a pain with shielded cable, made a custom coil to distributor wire). Also, you'll notice that I remounted the two Motronic relays, the starter junction box, and the made power point for the car. All three are no longer mounted on the stock bracket, but instead mounted directly to the firewall further back. This was to allow better clearance for the 180* aluminum bend for the plenum.
What you don't see in the pics is completion of installation of drive-shaft and associated items.
Jes
87 Milano 3.7 24v - race car
  #857 (permalink)
Old 03-25-2007, 12:33 AM
AR4me's Avatar
Worked most of the day on the car. I put together the coolant system - I thought that would be a 5 min job Nothing is ever that simple The fitting on the back (towards the firewall) is a different size than the Milano. In retrospect I actually knew this. Anyway, it meant running around to auto parts stores trying to collect the necessary pieces... It all went in - see pics. I also put together a throttle body (mixing parts from the two - the Milano and 164S). We mocked up the plenum again, cut the aluminum 180* bend a bit, and trimmed it to fit on the plenum. Colin took off to start the TIG welding of the aluminum pieces...
Jes
  #858 (permalink)
Old 03-25-2007, 12:38 AM
AR4me's Avatar
The battery was re-relocated from the trunk to the interior - mostly due to the custom fuel pump and filter occupying the trunk area. This also meant relocating the kill switch from the rear of the car to further front, since it would be kind of wasteful to run power cables all the way to the trunk and then back up front. It took some time, but I got it done.
So, what's left:
1. Finish welding plenum
2. Fab custom Alternator bracket
3. Fab Exhaust
4. Mount fuel pressure gauge & fuel level gauge
5. Mount fire ext., harness, and seat.
Jes
  #859 (permalink)
Old 03-25-2007, 03:28 PM
AR4me's Avatar
The 180* aluminum bend is welded 99% onto the plenum - Colin ran out of gas You may see the miscoloring and splatter on the aluminum. The throttle body mount is cut and trimmed and ready to be welded onto the other end of the 180* bend. Note the odd angle of the throttle body - necessary for the throttle cable to reach. I expect to use a 3" silicone connector between the throttle body and air-box. This morning I also wired up the new fuel level gauge as the FuelSafe sender isn't compatible with the Milano gauge. Still need to fab a plate for the mounting.
Jes
  #860 (permalink)
Old 03-25-2007, 03:56 PM
bobsiopener's Avatar
Hi Jes,
Whats the function of the gatoraid bottle?
84 GTV6 - 3.0L, headers, Sport Rear springs, Bilstien Shocks, LSD
87 Milano Platinum 74 GTV
  #861 (permalink)
Old 03-25-2007, 07:35 PM
nizam's Avatar
Originally Posted by bobsiopener View Post
Hi Jes,
That's the overflow coolant catch tank. In the AROSC race group, aside from the safety wire on the oil drain plug, they also want to see a "catch tank" for the coolant overflow. Instead of your car overheating and dumping coolant on the racing line, it will hopefully be captured in the catch tank.
  #862 (permalink)
Old 03-25-2007, 07:44 PM
in the stock car doesn't the reservoir act as the over flow as well or is there no over flow in the stock set up? if it does is there a rule that they must be separate?
  #863 (permalink)
Old 03-25-2007, 08:23 PM
AR4me's Avatar
Bob,
The stock cap will release pressure through the cap at around 10 psi, or so. This may eventually include coolant - as I have experienced a couple of times In that case you want a coolant catch tank to collect it. BTW, the 164 cap (or some of them) conveniently has a nipple from where you can collect overflow That's what I'm using - it fits on the Milano coolant bottle
Jes
  #864 (permalink)
Old 03-25-2007, 10:08 PM
AR4me's Avatar
...and some pictures of the new fuel related gauges mounted and wired up - fuel pressure to the left and fuel level to the right. Mounted in a carbon fiber board in the location of the stock center vents.
Jes
  #865 (permalink)
Old 03-26-2007, 07:56 AM
Did you guys try to MIG weld aluminum? Or does Colin have a TIG welder?
  #866 (permalink)
Old 03-26-2007, 09:00 AM
AR4me's Avatar
TIG! MIG aluminum?
Jes
  #867 (permalink)
Old 03-26-2007, 09:03 AM
Fortis 621's Avatar
I believe with aluminum you can only use TIG welding... With this project, I'm really pushing my envelope on my TIG welding abilities. Welding aluminum is not easy... especially when trying to weld a thin piece to a thick one. I am getting better, right Jes?
Sorry to hear that you will not be joining us this weekend .
Colin
  #868 (permalink)
Old 03-26-2007, 09:18 AM
AR4me's Avatar
Originally Posted by Fortis 621 View Post
II am getting better, right Jes?
You sure are! For that reason, what I handed you to weld was just a dummy - I have the REAL plenum (for you to weld) in my cabinet Ah, just kidding.
Besides, with Roxanne it has always been "function over form"!
Jes
  #869 (permalink)
Old 03-26-2007, 11:54 AM
Nikoror's Avatar
Send a message via MSN to Nikoror
what are you doing about the air/oil separator?
[URL="www.racingowls.com"]Rice University SAE[/URL]
  #870 (permalink)
Old 03-26-2007, 01:46 PM
AR4me's Avatar
I will be running the stock 164 oil vapor separator - bolts to the side of the 164 plenum.
Jes
