Old 05-12-2006, 05:56 PM
AxelBerlin AxelBerlin is offline
Hissing Aircondition
Hi guys,
everytime Iīm using the aircondition I have a hissing noise in the driver cabin. Itīs hard to locate, it seems like it is comming from everywhere. At first I thought it was the radio because it sounds like a noise from an amplifier in iddle but itīs the AC. The cooling is also not the best, is this maybe a sign of a too low level of AC coolant?
Axel
Old 05-12-2006, 08:55 PM
slyalfa slyalfa is offline
I think that is normal? As the liquid changes to a gas. I have a room A/C that makse that same hissing as well as the car A/C. The evaporator in the alfa is very close to the vents if you look in the center vents you can see it. So I think the hissing is noticable do to the locatation.
what does you site glass look like when it is runing full blast?
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 05-13-2006, 12:12 PM
Hi,
at the moment I can not check this because the car is till June iin the service for blown head gasket I will check this asap if I have the car back.
Since the cooling is not realy good and the air is only a littlebit cold I thought that it is a low level sign.
Axel
Old 05-13-2006, 07:10 PM
VerdeVeepster's Avatar
VerdeVeepster VerdeVeepster is offline
Send a message via AIM to VerdeVeepster
The hissing is normal, but if it's not cooling well and the car is running hot then it might need attention. The best way to ensure a long life for your a/c is to use it a lot, even in the winter.
Evan
-88 Milano Verde
Old 05-14-2006, 05:01 AM
Nipper's Avatar
Nipper Nipper is offline
I was told by a auto electrician, or who ever refills the a/c on cars, that the hissing noise coming from my a/c was due to the gas in my system was a older version, different gas that they used to use. Apparently when the gas starts to get low it makes that hissing noise. My a/c still pumps out plenty of cold air so he said to let it run out before he puts the new gas in. The new gas they use doesn't hiss and is better for the environment or something, I was told.
Adam D
89 Alfa 75 3.0 V6 & 84 Alfa GTV
Old 05-14-2006, 05:12 AM
Todd's Avatar
Todd Todd is offline
If you operate your A/C with a low charge (ie not cooling well), your certain to severly damage The system. The Compressor needs cool gas return to remove heat of compression. First to go is the oil which will overheat, and suffer from poor system circulation. It will then circulate nasty acidic oil completely contaminating the system. Then they can really sell you some parts!
Todd
Commercial/ Industrial Hvac/Refrigeration Tech
77 Alfetta Sedan
87 Milano Verde
Old 05-14-2006, 09:46 AM
the old gas is R-12, the new is R-134
the older gas is very bad for the environment and all new cars run on the newer 134, however, the 134 is a less efficient cooling gas so if your 12 unit still works fine then it should be blowing nice and cold. If it isn't blowing cold and you don't want to spend a lot of money on future recharges of R12 then you can have the system converted to 134 and you will be able to use that gas from there on out.
i should also specify, I didn't mean that even if it's not cold you should run the a/c. What I meant was that the only way for the a/c oil to lubricate the system is when it is running. Most a/c units break come springtime or after storage because they haven't been used in a long time, similar to if you park your car for a year then just try to turn it on without squirting some oil around the parts that need it.
Evan
-88 Milano Verde
Old 05-15-2006, 08:06 PM
Todd's Avatar
The problem with non usage is in the compressor shaft seal. It is a delicate item that uses close tolerances and a thin amount of oil to make the seal. You should use the A/c at least once a month no matter what the outside temp is to keep this seal lubricated and sealing. In very low ambient temps the low pressure switch may keep the Compressor from comming on. In that case with the engine off use your hand to rotate the pulley a bit, or figure out a way to introduce heat into the condenser. You could also run the heater and get the interior really hot, then switch to A/C.
Note that this only applies to open drive style compressors. Your home Compressor is hermeticly sealed.
77 Alfetta Sedan
87 Milano Verde
Old 05-16-2006, 05:45 AM
The Milano lets you run the heater and the A/C at the same time.
I use this a lot in the winter as this is the best way to defog the windows.
