Old 04-20-2006, 05:00 AM
oz3litre's Avatar
oz3litre oz3litre is offline
V6 thermostat
My 3 litre needs a new thermostat and so far it looks like we have to get one from Alfa at a cost of $120! Ouch! The guy from The Spare Place here in Adelaide has been told that one from a 164 can be fitted to the 75, despite the different orientation of the engines, and he is going to check it against a 75 one he has on an old motor at home tonight. The 164 one is only $40 and he has them in stock.
Does anyone have experience with 75 thermostats?
1988 75 3 litre, 1990 75 3 litre Potenziata, 1984 GTV 2000 (sold), 1992 Alfa 164 3 litre, 1990 Volvo 480 Turbo
Old 04-20-2006, 05:06 AM
Alex Csank's Avatar
Alex Csank Alex Csank is offline
Send a message via AIM to Alex Csank
Here in the USA, the 2.5 and 3.0 thermostats are available for $27.90 from Ianternational Auto Parts. You would need to re-use the thermostat housing and would probably want to replace the bolts in the housing ($1.80 each - needs 3). I'm pretty sure that you can have one shipped to you from here.
Cheers,
Alex Csank
Chair, Alfa Century 2010 - The AROC USA ALFA Centennial Convention
E-mail: alfaromeodriveralex@gmail.com or alfacentury2010@gmail.com
Mobile: (757) 636-9513
82 Spider Veloce (Desideria - Kathleen's)
84 GTV6 Maratona (Mona - resto project)
88 Milano Verde (Trogdor The Burninator)
"My name is Alex and I am an Alfaholic."
Alfisti are always welcome in our home!
Old 04-20-2006, 05:13 AM
oz3litre's Avatar
V6 thermostat
So does that mean you can remove the thermostat from the housing? The 164 one looks like it is all one unit. I haven't taken mine off yet because we need the car while I have the 33 struts off.
Old 04-20-2006, 05:51 AM
Alex Csank's Avatar
I believe that the factory replacement is the whole housing. You can remove the thermostat from the housing and replace it keeping the housing, but you will have to replace the thermostat screws.
Cheers,
Alex Csank
Old 04-20-2006, 06:02 AM
oz3litre's Avatar
V6 thermostat
Thanks very much for the info Alex. Sorry to ask so many questions. Is the the thermostat common to other brands of cars and if so which ones?
Old 04-20-2006, 08:38 AM
JoeCab's Avatar
JoeCab JoeCab is offline
You would NOT want to use a 164 thermostat as they have a different opening temperature.
Joe
Old 04-20-2006, 10:51 AM
MitchW MitchW is offline
The problem is that none of the aftermarket thermostat's I've tried on my Verde fully close. I'm currently running the Zat 165 degree thermostat and I made sure that the housing was clean and the thermostat seated but it still takes forever to warm up.
I've still got the OEM one but it tends to stick open or closed at inopportune times.
Mitch
Old 04-20-2006, 11:44 AM
Alex Csank's Avatar
My thermostats (in my Milanos and GTV6 4 total) all work fine. I have changed two of them and the rest are probably aftermarket too. All Alfas take a long time to warm up because of the large oil capacity. Just drive them carefully and don't exceed about 3000 RPM until they get warm and theoil pressure drops to normal levels.
Cheers,
Alex Csank
Old 04-20-2006, 01:18 PM
slyalfa slyalfa is offline
you have to be kidding. the V6 heatsup superfast. and I think they all could use a oil cooler.
mine get warm so that the heater starts to heat by the time I drive out the parking lot. and it is just getting to full temp by the time I hit the freeway a few blocks away. the oil take a lot longer to heat then over heat(the normal state in a alfa) as I get see just watching my oil PSI drop.
if you want slow to heatup try a 68 toyota 4cyl or almost any 4cyl they seem to be still comming up to temp just as I shutthem down after driving to work.
I rember I would start my 68 in the winter and let it run for a 1hrs in the driveway to get it so the windows would defrost. just way too much iron for 2L of displacment.
I love the 75 in the winter as it seems to have instant heat + the heated seats
I think the only car I have seen with better heat was one that used the A/C in revirse so the cold was put outside and the heat inside untill the car warmed.
now that was real instant heat.
1987 black Milano Verde
1972 White spider 2000 Veloce
Old 04-20-2006, 01:30 PM
JoeCab's Avatar
A Milano with a good thermostat and a cooling system in good working order should take about +/- 10 minutes of driving to reach the point where the thermostat opens and you can see the temperature gauge drop.
As Sly said, it's usually about 5-10 minutes beyond that when the oil is warm enough to start using full throttle.
Joe
Old 04-20-2006, 11:24 PM
Fritzi Fritzi is offline
'had the same experience - ordered the replacement insert from IAP just because Centerline was out of stock and threw it out after 1 week and returned it to IAP. It was not only cheap and crappy looking, it also didn't close fully and my car didn't warm up. Put back my old OEM unit.
I second Alex's advice with new bolts - they are normally rusting in the lower housing and you don't want to strip them - clean the housing and threads and use antiseize - don't overtighten, it's aluminum
Old 04-20-2006, 11:28 PM
JoeCab's Avatar
I really WISH we were just out of stock on the OEM thermostats. Sadly, though, this part has gone the way of the Dodo Bird - NLA from Alfa and every manufacturer out there.
Joe
Old 04-21-2006, 12:29 AM
Keep the old thermostats they can be milled to take a normal thermostat like I run.
I posted this before it is very easy to do if you have a mill.
strange this never used to happen why is it showing the unformatted images?
  #14 (permalink)
Old 04-21-2006, 08:27 AM
oz3litre's Avatar
V6 Thermostat
Thanks slyalfa. What type (ie what do you mean by "normal") and temp range thermostat do you use?
  #15 (permalink)
Old 04-21-2006, 09:15 AM
JoeCab's Avatar
Sly,
How do you bleed the system with your housing? It looks like the bleeder hole is blocked by the gasket.
Joe
You
