On the Milanos it has a safety two-stage fuel-supply setup... Turning the key to ON does not provide fuel... Cranking DOES (in the first stage), but once you release the key and the engine is running, the movement of air through the AFM triggers the 2nd stage to provide fuel from there on out until the engine stalls/dies... (Its a safety-thing in the event of an accident.)
When I first installed a stand-alone engine management system on my Verde (and before I was able to master the double-relays up on the passenger-side fire-wall), I had trouble starting the car with the stock L-Jet ECU unplugged... It would start and sputter while I was cranking the key, but die just as soon as I released the key (meaning that the stage one fueling described above worked just fine, but that the 2nd stage also described above would fail to activate and take over fuel-supply as soon as I released the key.)
To test the theory, on a few occasions I would actually keep cranking the key and drag the starter (very bad for it), just to verify that this was what was actually happening and indeed, it would keep running while I kept the key cranked, but stall just as soon as I would release the key - so, fuel issues. In my next stage of unassisted exploration, I found a mechanical solution to my electronic challenge;
I plugged the AFM back in and just left it dangling there in the engine-bay - tied-back with a zip-tie! I jammed a number 13 spanner (a wrench, a tool - whatever
) in the flapper inside the AFM and it worked!!!
It triggered fuel - it turned the fuel-pump on continously! Keep in mind that I was now running an open air intake with simply an air-temperature sensor in the new intake pipe, so the AFM was just hanging there - open - (with no vacuum-issues) just to trigger signal to the double-relay...
Later that day over at Michael Harris' house (after a good laugh), he and I tracked-down the two pins in the connector of the AFM-portion of the harness and added a jumper that also triggered the fuel-pump relay full-time... (I could now also return the # 13 spanner to Group 2 and remove the AFM altogether!) Even later yet, I was able to install a proper relay for the fuel-pump and remove the last of the OEM Bosch harness and everything from L-Jet...
I really did learn about relays, L-Jet and the restrictive AFM the hard way...
