Well,
I'd decided that my project 75TS would need to be lowered, and I'd found a nice pair of lowering springs off my old GTV6 under the house. I reckon they take it down about 40mm.
Having read this thread and all the horror stories about getting the t-bars out the crossmember, I'd decided that I would make do with just dropping it by 1 spline at the wishbone end.
This I did last night and discovered that this droped it nearly 60mm
Full of dread I went out to the garage this morning to try and get the first bar out of the crossmember, fully expecting a battle as bad or worse than Jim's, seeing as the car has endured 15 UK winters
Before trying to extract it I gave it a few good whacks with the hammer to get it ringing and then had a go.
I was totally amazed and delighted when it just slid out as easy as you please
I'm so delighted that I had to run in and put this post up
Mind you, I've still the other side to do...
Here's hoping it comes out as easily
