Old 11-03-2009, 08:36 AM
Send a message via AIM to m4ff3w Send a message via MSN to m4ff3w Send a message via Yahoo to m4ff3w
Oil pressure at hot idle
I just bought an 87 Gold. It has been very well maintained.
My oil pressure at hot idle is really low. As in barely registering above 0 low.
Anything above idle and cold idle, pressure is good.
I changed the oil last night to 20w-50, hoping it would help (I believe 10w-30 was in there) but didn't change it much.
How low of a pressure at hot idle is acceptable?
Thanks!
Matthew
Old 11-03-2009, 08:46 AM
NMMilano's Avatar
As long as the light isnt on dont worry about it, thats how they are.
87 Milano Platinum
70 Fulvia 1.3 Rally S
Old 11-03-2009, 10:54 AM
GregSef's Avatar
Member
The gauges and senders are notoriusly inaccurate. You can remove the idiot light sensor and screw in a mechanical pressure gauge to confirm you have good pressure. Then put the sender back on. The pressure gauge sensor is a PITA to remove. Both senders are available from the usual suspects. Search the forum for a procedure to make an old sender work if you don't mind drilling a hole in it.
Greg
1974 Berlina Vintage Racer, 1987 Milano Platinum (LeMons Car)
1995 BMW 540i Sport-Dinan Chip, 1966 Corvette Coupe 327-350, 1993 Saab Turbo
Old 11-03-2009, 12:38 PM
Mine is like that too, its normally about one needle width aboue zero. I have tried several different types of oil (15w-40 and 20w-50), and shell rotella t 15w-40 non synthetic shows the oil pressure im most comfortable with.
Old 11-03-2009, 12:45 PM
Ok, I was just a bit concerned.
Thanks yall.
-matthew
'87 Milano Gold
Old 11-04-2009, 10:06 AM
Graham D's Avatar
For peace of mind, rent (free) a fuel pressure test kit from your local auto supply store. It will (should) include a selection of threaded adapters to suit various applications; you want the M10x1. Install in place of the stock sender, start the motor and read the gauge. Remember that you also have a red low oil pressure warning light by your fuel gauge that would be lit if you were in trouble. Changing the sender is not easy as there is little room for wrench swing and the clearance on the bottom is usually too tight for a stubby 14mm wrench. The tool I made from 3/8" rod stock and a donor 14mm wrench though makes it easy. It's 15" tall with a 6" handle with about 7/8" between the wrench throat and the shaft. Name:  P1000837.JPG
If you have a set of 3/4" drive 12pt sockets, use the 1 - 11/16, a short piece of 3/16" or M6 fastener (cut the head off a bolt) and some grease. Use the grease to stick the rod in the sender body's slot, drop the socket over and turn to remove. If, when you put it all back together, you do not have a new copper washer, just put some sealant such as Permatex #2 on both sides; it will help keep the washer in place while you fish around for the hole.
Old 11-04-2009, 10:32 AM
Wow, thanks Graham.
-matthew
'87 Milano Gold
