While I have the door-panel off of my RR door (after it clammed-up on me one day about two years ago), I want to also fix that window-function. Is that not fortuitous - the same bloody door!? (I a never that lucky)!
So, yeah - I understand - it's a "bad regulator", but what are we talking about here!? I have it out and the motor seems to work just fine! Is it the part that the motor is molded too - is that the gear-housing? Is that what is bad, or is it the cable-mechanism that disappears into the door towards the window that has some sort of a screw-cable mechanism in there that is slipping!?
My window rolls down just fine and will roll up by itself from about the mid-point on up. It makes that whirring stripped-gears sound trying to roll it up from the bottom to about the mid-way point though. I have to help it along and then it goes fine the rest of the way!
I tried another motor that I have here, but it does the same thing!? If it is inside the gear-housing on the motor, then that one's gear-set in that housing might just be bad too, so that doesn't tell me anything...) Gimme the gold here please!
