Old 11-01-2009, 06:59 PM
Removal of ARC Computer
Quick question,
Driving my Milano on the track this summer with the ringing sounds and flashing lights from the the ARC drove me nuts.... If I remove completly the ARC will that have an effect on the engine performance? oil psi, water temp?
Thank you for your help.
Orazio
86 Milano platinum ([COLOR="Red"]Getting There[/COLOR])
83 Autobianchi A112 Junior (with Abarth Engine) [B][COLOR="Red"]For Sale[/COLOR][/B]
Old 11-01-2009, 08:24 PM
I removed mine to no ill effect. It's easy to fix, however. I can't find the link now as I'm on my phone, but search for "The Real ARC fix" on this board.
87 Milano Platinum - 91 Volvo Bertone Coupe Turbo 4 - 98 Volvo S70 T5M
Old 11-01-2009, 08:35 PM
Gubi's Avatar
Here's the thread on how to fix it right:
http://www.alfabb.com/bb/forums/mila...ng-lights.html
Alternatively you could unplug the warning light panel, but if you do that you lose your brake, parking brake, coolant level, and alternator warning lights. So it's really not a smart idea.
1991 Spider
1987 Milano Gold
Old 11-01-2009, 08:40 PM
nizam's Avatar
Removing the ARC won't make the car run any different.
However, when properly working, and runs as intended by its designers, it gives you the required key diagnostics of the car. Why wouldn't you want to know if something wasn't working?
Use the link Gubi provided above. It's really quite a simple fix.
Old 11-02-2009, 12:16 AM
Rookie ROX's Avatar
You having ringing sounds?
I'm with the above. The ARC does provide important information on major failures, so I personally wouldn't remove it completely. Try the Gubi Fix first, if you're still having issues, then I'd suggest also hitting up Craig's website which also provides some hints on common issues that cause it to flash.
ROCK ON
R~R
Old 11-06-2009, 06:40 PM
i did the 'The Real ARC Fix' and it works perfectly! lights work when they are ment to.
1978 116 gtv
1988 3.0 75
