Old 03-03-2005, 08:10 PM
DonBeeson's Avatar
DonBeeson DonBeeson is offline
Speedometer sender
Hey, I took out my Milano today and the speedometer decided to completely not work, it hasnt worked for the few times i went out today, I checked international auto for parts, but the closest i came to was the gtv6 speedometer sender. Will this fit in my 88 milano, or did things change between the two?
Old 03-04-2005, 07:35 AM
AR4me's Avatar
AR4me AR4me is offline
What makes you think it is the sender? The speedometer (and tachometer) in the milano often fails - I had one where tapping the instrument cluster would wake it up - after a while that didn't work either...
Jes
87 Milano Verde - daily driver - [URL="http://www.alfabb.com/bb/forums/showthread.php?p=363643#post363643"]Juliet[/URL]
87 Milano 3.0 Motronic - budget race car - [URL="http://www.alfabb.com/bb/forums/showthread.php?t=27358"]Roxanne[/URL]
87 Milano 3.7 24v - race car
Old 03-04-2005, 11:36 AM
AlfaNewB's Avatar
AlfaNewB AlfaNewB is offline
Send a message via AIM to AlfaNewB Send a message via MSN to AlfaNewB
if the speedo acts funny, but everything else remains normal, then its the sender. i had this problem, havents fixed it yet but its comon sence, why wouls the speedo drop and jump, while everything else is normal?
and when i changed gears it would work again.
Old 03-04-2005, 01:20 PM
DonBeeson's Avatar
Mine just hasn't worked period, im gonna jack it up in a few days and take an ohm meter to everything, see whats happening
Old 03-04-2005, 02:20 PM
AR4me's Avatar
Because of faulty speedo electronics - coils getting brittle, shorting out with temp etc, a ton of reasons.
How do you know if you haven't fixed it yet? Though, you gear change impact points in that direction.
Jes
Old 03-05-2005, 11:03 AM
AlfaNewB's Avatar
damn in really need to double check my typing LMAO this is horrible. to me its comon sence the sender maybe loose on my car who knows, but it dosent make sence for everything to work properly and the speadometer to jump ar ound after 80 mph then act wierd for a few hours and back to normal. the speedo jumps and the rpm is normal.
Old 03-05-2005, 11:15 AM
DonBeeson's Avatar
speedo and rpm have two different senders i do believe
Old 03-05-2005, 01:08 PM
JoeCab's Avatar
JoeCab JoeCab is offline
What you have described is a fairly normal failure mode for the Milano speedometer. It is usually a bad or intermittent connection inside the speedo or the box underneath the rear seat cushion - failures of the sending unit at the tranny are less common.
Joe
Old 03-06-2005, 10:17 PM
sidewaysalfa sidewaysalfa is offline
Thanks for the tip Joe. Have had this problem for months.
But if I finally fix my Milano speedo/odo problem my increadible gas mileage will go away.
I am up to about 97mpg!!! And the car does 120mph in first gear.
Not bad for a car with 300000 miles, 80000 on the motor.
Paul Blankenship AROSC
76 Alfetta GT Time Trials and Wine Tours; 88 Milano - Daily Driver; "Reality is what gets in the way of my personal life"
Old 05-30-2005, 07:12 AM
Tim-Spruill Tim-Spruill is offline
My Milano has the same problems with the speedo. I replaced the sending unit with one that was know to work and that fixed the problem temporarily. The speedo will work fine until a certain speed and then quit. When I let off the throttle it comes back, until I get back on the throttle. The speed at which this is a problem seems to get lower as the temps go up. Has anyone had the sending unit cut open to see what is inside? I am just curious. And if the sending unit is less common as a problem, has anyone had any luck with fixing the problems with the black box or the speedo itself? I like being able to know how fast I am going.
'88 Milano Verde- Maura
'85 Spider- Abriana
Old 05-31-2005, 02:38 PM
Alfa147-Italia Alfa147-Italia is offline
Send a message via ICQ to Alfa147-Italia Send a message via MSN to Alfa147-Italia
I don't understand what do you mean when you say the unit sender ?
I have the same proble too . my RPM is fine , but my spidometer works but it jumps up and down up and down ...
Does anyone have some pictures of the whole thing . it will help a lot !!!!
So how can i fix it ?
Can i fix it by myself ?
Thanks!!!
Shaul 75
Alfa Romeo 75 1.6 Carb' 90
Israeli Alfa Romeo Club
http://www.iaroc.org.il
[IMG]http://img58.exs.cx/img58/1866/1820501810qi.jpg[/IMG]
Old 10-18-2005, 05:58 PM
euroshark's Avatar
euroshark euroshark is offline
Send a message via AIM to euroshark
I say build a new cluster using VDO 3 3/8" Electronic Tach and Speedo... Im investigating this because my tach is nearly deceased, and my Speedo has gone haywire a few times... the Tach is a very straightforward installation, but the Speedo may require a pulse / hall effect trigger, which VDO sells, but Im not sure where I'd install it...
Daily: [B][COLOR=Red]1991 164L[/COLOR][/B] 5 speed, Black on Black, totally stock
Project: [B][COLOR="Navy"]1983 635CSi Euro[/COLOR][/B] 5 speed, High compression "dirty" M30B34, Getrag 262 Dogleg, Bilstein Sports and H&Rs, 16x8 BBS Style 5s... Rolling restoration
Old 10-18-2005, 07:41 PM
DonBeeson's Avatar
can you send me a link? both of mine need to be replaced.
  #14 (permalink)
Old 02-21-2008, 04:57 AM
romroc romroc is offline
Here's a new wrinkle: the speedo needle goes to the max and the odometer starts racing along with the sound of a motor inside the guage cluster. Is it the black box, the sensor, or the speedo? this particular car has only 38000 on it and has sat and sat.
'58 Sprint
'82 Spider Veloce
'84 GTV-6
'89 Milano Gold
'93 164L auto
'95 Corvette C4 targa auto
'00 BMW 323 Sportwagon auto [wife's car]
The Rock
  #15 (permalink)
Old 02-21-2008, 05:45 AM
grale grale is offline
Where is located the sending unit on a 1.8 Turbo car?
A friend of mine told me that on his car (2.0 TS) it is located inside de car under the rear seat, but I checked that in mine, and it isnīt...
Regards
Carlos Oliveira
