REAL fix for ARC blinking lights - Page 3 - Alfa Romeo Bulletin Board & Forums
post #31 of 156 (permalink) Old 04-22-2008, 03:14 AM
EXCELLENT fix!!! I fixed a spare ARC last weekend (never worked right) and it worked so well I also fixed my good (but still with blinking lights) ARC. Both work great. Best fix ever. I even decided to spend the time and install a resistor to get rid of my low oil light (GTV6 engine). No more lights!!!
As far as the standoff is concerned. I used some 1/8" aluminum tube cut to the right length as a standoff and then just riveted it all back together.
dbgrubbs is offline
post #32 of 156 (permalink) Old 04-22-2008, 09:07 PM
super-racer's Avatar
Send a message via AIM to super-racer
Great fix Tom! Thanks to your insight and Nizam's help I got mine fixed tonight. I've owned this car forever and tonight was the first night I saw the ARC function correctly. This is awesome!
Fabrizio
super-racer is offline
post #33 of 156 (permalink) Old 04-24-2008, 04:52 PM
larsjm's Avatar
After finding this thread I immediately went to radio shack to buy a new voltage regulator and tried the fix.
It definitely works!
No more random blinking lights! I can actually rely on my ARC to give correct information about my Milano now! Thanks for your hard work in finding this fix.
larsjm is offline
post #34 of 156 (permalink) Old 04-26-2008, 01:54 AM
Thumbs up
Excellent! It worked for me too. Thanks for the fix.
The only warning light I get now is the 'warning lamp efficiency' warning light. I'd like to fix this but I don't know where to begin. Anyone got any ideas?
jaffa is offline
post #35 of 156 (permalink) Old 04-26-2008, 02:31 AM
Craig's Avatar
This should indicate a problem with one or more of the following:
Oil pressure warning lamp
Coolant temp warning lamp
Low fuel warning lamp
Craig,
1988 75 TS, 1989 164
[COLOR="Red"]My web sites:[/COLOR]
Craig is offline
post #36 of 156 (permalink) Old 04-26-2008, 06:55 PM
Cheers Craig.
jaffa is offline
post #37 of 156 (permalink) Old 04-27-2008, 03:23 PM
kredden's Avatar
Finally found my spare ARC and did this fix, great fix! Instead of using a rivet I just got some standoffs from Radio Shack (276-1381), shaved them down a bit on the grinder wheel and used a slightly longer screw on the side going through the heat sink. Works great now, thanks for figuring out this fix!
Kevin
Milano registry custodian(
kredden is offline
post #38 of 156 (permalink) Old 04-27-2008, 07:04 PM
One thing you might want to try is to clean the contacts of the ARC. I did this with a dremel tool and the blinking stopped. The mylar embedded contacts can corrode and still look fine. This is also recommended for the speedo guage cluster, or any contacts for that matter. Took two seconds.
'58 Sprint
'82 Spider Veloce
'84 GTV-6
'89 Milano Gold
'93 164L auto
'95 Corvette C4 targa auto
'00 BMW 323 Sportwagon auto [wife's car]
The Rock
romroc is offline
post #39 of 156 (permalink) Old 06-10-2008, 12:20 AM Thread Starter
Gubi's Avatar
Well, it's been working flawlessly ever since the redo with the thermal grease. Based on all the feedback (and helping Andy fix his Verde last week) I think I'm going to call this one good. I cleaned up the procedure and wrote it up as a tech article for the ARA newsletter - it should go out in the July issue.
Thanks to all who tested this out.
1991 Spider
Gubi is offline
post #40 of 156 (permalink) Old 06-10-2008, 01:03 AM
AlfaNewB's Avatar
Send a message via AIM to AlfaNewB Send a message via MSN to AlfaNewB
i didnt read the entire thread, but on a car you have 12 volts for power your negative for ground and a 5 volt reference, the 5 volt reference is a signal wire to the ECU, now dose this arc have any connnectiosn to the ECU, or dose it just have sensors connected directly from the ARC?
AlfaNewB is offline
post #41 of 156 (permalink) Old 06-10-2008, 12:13 PM
I do not think there is anything going to the ECU. the ECU even has its own wireing harness(WITH NO FUESES)
The ARC is 2 parts the mane part is over the glovebox and this is where everone thought the problem was before. The other part is just the display board. but the display board is where the real problem was. so every one was looking at the wrong part so this is why no one could fix it. there was nothing wrong with the part everone looked at.
1987 black Milano Verde, 1987 (made in 1986)blue $200 gold with ABS and LSD
1972 White spider 2000 Veloce
slyalfa is offline
post #42 of 156 (permalink) Old 06-10-2008, 02:49 PM
Rookie ROX's Avatar
Could you post up this new tech article for those of us who drive with kangaroos and koalas in the passenger seat?
ROCK ON
R~R
Rookie ROX is offline
post #43 of 156 (permalink) Old 06-10-2008, 03:46 PM
Craig's Avatar
Just use a mirror to read it
Ok, all jokes aside the ARC display is one part of the car where LHD/RHD doesn't matter.
Craig,
Craig is offline
post #44 of 156 (permalink) Old 06-10-2008, 04:40 PM Thread Starter
Gubi's Avatar
I'd pay to see that
Basically it's almost verbatim what I had in the first and third post in this thread...just cleaned it up, added some details, and an additional picture
1991 Spider
Gubi is offline
post #45 of 156 (permalink) Old 06-19-2008, 10:36 PM
First of all: Thanks for this terrific fix!!!!
I'm a relative new Alfa 75 owner,but I've been reading about this "cronic" problem (witch I had too) and your discover must be WORLDWIDE commented! I change it with a 7805 too and now I got two stops:the blinking lights and the "what is this?" question of my passengers!
After the fix I got two warnings: "Parking lights and rear fog lights efficiency warning light" AND the front left "open door warning light" ONLY when I turn on the master lights. Weird behavior!
Any ideas?
gatitopy is offline
Replace with
