Battery Disconnect on Milano - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 25 (permalink) Old 03-12-2017, 08:22 PM
Del
Probably not much of a worry anyway, as the young types who are the most likely to steal your car cannot drive a manual transmission equipped car, lol. And, as I mentioned before, they would never find that almost invisible hood release lever.
You can most likely fix your ARC by installing the higher power 5V chip, and also clean the multiconnectors on the back of the ARC module, and the ARC computer. It is possible though that the computer itself is going. A few years ago I had to try two different used computers to get the ARC to work correctly. I did install the better 5V device previously. During our cold weather here recently, well, cold for here, ~25F, the ARC did act up, but I think it was just poor/dirty/loose cable connections. As soon as the car was turned off and restarted, everything was fine again. It works properly now with warmer weather.
Del
Seattle
previously owned since 1964:
Del is online now
post #17 of 25 (permalink) Old 03-13-2017, 06:36 PM
Potenziato's Avatar
I would buy a Ctek 8 step 4.3 battery charger and tender if I was going to leave the car for more than a week.
These Ctek chargers are awesome and revived an older AGM battery in my M3. They are only around $70 on Amazon and are the OEM for Porsche, BMW, Corvette, Alfa Romeo and etc.
A modern car will eat the battery in a weak with the number of electronic devices.
Louis
2011 M3 e90 ZCP no sunroof, 2004 M3 e46 no sunroof , 1987 Milano 24v, 1987 Milano Verde
Potenziato is offline
post #18 of 25 (permalink) Old 03-13-2017, 07:14 PM
Del
I just use an el cheapo HF tender, works fine, both with the cars, and also for the boat which can go all winter without use.
Del
Seattle
Del is online now
post #19 of 25 (permalink) Old 03-13-2017, 08:28 PM Thread Starter
crackie's Avatar
I have the el cheapo HF trickle charger, but have never used it.
Del - sounds like it has worked well for you?
--Scott
Current: 85 GTV6, 69 Duetto, 87 Milano Gold. Past: 65 Giulia Sprint GT, 77 Alfetta, 79 Alfetta.
crackie is offline
post #20 of 25 (permalink) Old 03-13-2017, 09:12 PM
Del
Seems to. Keeps the car battery (Costco/Interstate) up, and also does a good job of keeping the marine deep cycle battery (Costco/Interstate) up for months at a time during the winter.
Del
Seattle
Del is online now
post #21 of 25 (permalink) Old 03-13-2017, 09:23 PM
I've also got one and happy with it. I'm probably going to pick up a couple more.
Richard2 is online now
post #22 of 25 (permalink) Old 03-15-2017, 02:44 PM
Potenziato's Avatar
Are guys talking about the Harbor Freight el cheapo $8.99 trickle charger? That thing is a POS. It puts out 15 vdc with no surge protection or voltage regulation.
It might work on the Milano but please don't try it on any modern car.
Louis
post #23 of 25 (permalink) Old 03-15-2017, 05:55 PM
Del
Do you mean the as labeled 500mA "float" charger?
Interesting, as I've use one for a couple of decades, and it has done a good job of holding both my 164LS Interstate battery up between trips/usage, and also the Interstate Marine battery in the boat, which goes probably 7 months at a time without summertime use. Batteries seem to last at least 10 years.
Haven't come across any damage in that time, but would like to know.
Del
Seattle
Del is online now
post #24 of 25 (permalink) Old 03-15-2017, 07:26 PM
Potenziato's Avatar
Yeah, I don't trust the Harbor Freight float charger. There are plenty of cheap float chargers based on a switch mode power supply instead of a transformer.
The Harbor Freight is transformer based.
If the line voltage goes up, the charger voltage goes up. The more load on the charger, the lower the voltage. The switch mode chargers will take current from 100-240v and always put out a regulated dc output voltage. I've seen inexpensive ones for $20 or less.
Louis
post #25 of 25 (permalink) Old 03-15-2017, 08:03 PM
Del
Well, it is interesting. While I've had no problems whatsoever with any batteries I've used it on for a longtime, I will check the output voltage that people complain about. I have no reason to expect the input line voltage to the unit to go up, but the output sounds like it could be suspect on many units. I will note that most say the voltage they mention is somewhere around ~14.3-14.5, which is basically what the volt meter in the 164 generally reads with the car is running.
I will look around for a better unit, but I will probably continue to use this one, as it seems to do a decent job. As I mentioned, the boat Interstate marine battery will sit unused for about 7 months before the summer usage, and it is always up just right.
Any recommendations? I see Black and Decker advertises a supposed switch mode charger, seen on eBay for ~$20-30.
Del
Seattle
Del is online now
