front flex disc Milano replacement? How? - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 03-05-2017, 02:59 PM Thread Starter
How is the front flex disc replaced in a Milano? The access hole beneath the bell housing seems too small to squeeze a disc into there.
4domani is offline
post #2 of 5 (permalink) Old 03-05-2017, 04:11 PM
Duk
Duk's Avatar
The tailshaft needs to be removed. The coupling has to be slid off the bolts in the flywheel.
Duk is offline
post #3 of 5 (permalink) Old 03-06-2017, 05:27 AM
kredden's Avatar
There is a pinch bolt you can get to in the access hole. As Duk says, if you unbolt the rear and the center support you can slide the driveshaft out, it may require some persuasion depending on when the last time it came out was (I used a plastic dead blow hammer).
Kevin
Milano registry custodian(
kredden is offline
post #4 of 5 (permalink) Old 03-06-2017, 11:16 AM
Del
At least you don't have to pull the engine if you need to change the rear main seal.
Del
Seattle
previously owned since 1964:
Del is offline
post #5 of 5 (permalink) Old 03-06-2017, 06:38 PM
NMMilano's Avatar
Might as well replace them all when you're there. 10 years peace of mind.
87 Milano Platinum
76 Alfetta GT race car
70 Fulvia 1.3 Rally S
68 Fiat 850
NMMilano is offline
Replace with
