Silly question - trunk badge removal - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 03-01-2017, 01:13 PM Thread Starter
I've been sick for a couple of weeks and haven't gotten to do anything Alfa related. Finally starting to feel human again today, so I thought I would install a couple of new grill and trunk badges that I got off eBay just to say that I did something today. The old front one popped right off and I was done in like a minute.
Went around to the back and that one will not budge. I can get either side up maybe 1/16", but I'm afraid I'll damage the deck lid if I pry any harder. Is there a secret trick to releasing it from the inside or something, or has it just been glued down really well?
Sent from my Nexus 5X using Tapatalk
radioal is offline
post #2 of 4 (permalink) Old 03-01-2017, 02:24 PM
Del
Looking at the Fiat eper, External Accessories, type plate, it looks like there is a single rubber bushing on the inside of the trunk holding that badge on, holding a pin on the back side of the badge. The pin on the back side of the badge should slip out of that bushing, but may be tight from old age. There may be some adhesive as well. Mine has the bushing inside. I can barely feel it with a finger, but the badge also feels like maybe it is glued as well, the pin used just for centering.
Unfortunately, the bushing is in behind the inside sheet metal. Try squirting in a little WD-40 behind the badge. Try prying gently, levering on the badge on two sides, not just one, as that just cocks the pin. Perhaps also try to rotate the badge at the same time to help free the pin from the bushing.
Del
Seattle
previously owned since 1964:
Del is offline
post #3 of 4 (permalink) Old 03-11-2017, 11:18 AM
RobNH's Avatar
Thumbs up Takes a little perstence and patience
I used one of the tools in my plastic trim removal kit, and as Del suggested, rotate position around the perimeter and pry evenly at every angle on the emblem. I have also heard of people using heavy gauge dental floss and thick plastic cards.. what worked for me was the trim removal tool. The top knob is the one that won't budge. Work the other two up until you have clearance under it, and then attack. Whatever you use, it should be plastic or you WILL sratch the paint.
RobNH is offline
post #4 of 4 (permalink) Old 03-11-2017, 04:34 PM Thread Starter
I'll have to pick up some plastic trim tools. I haven't had any more time to play with the Alfa recently.
radioal is offline
