3.0 Head Identification Question - Alfa Romeo Bulletin Board & Forums
post #1 of 24 (permalink) Old 11-17-2016, 06:19 PM Thread Starter
Send a message via AIM to DOM!
Hi All,
I am feverishly assembling my Verde's motor. I ordered a new sprocket and distributor gear for the heads I have from Larry @ APE. He brought up an interesting point. He asked if they were 164 heads. I assumed they were from a Verde. Now for long reasons I don't have the original heads from my motor. These heads came sans sprockets.
But Larry brought up a point about the distributor drive gear and how the gears are different. Now Steve had said the sprocket was different but now I am concerned due to the lack of origin of these heads, do I have 164 heads? Now they came with the block off plate but I am not sure if Larry is sending the right gear for me!
Domenic
DOM! 1987 Milano Verde 1983 GTV6
2009 VW Jetta Sportwagen TDI 2003 Ducati 999
DOM! is offline
post #2 of 24 (permalink) Old 11-17-2016, 06:20 PM Thread Starter
Here's a picture
DOM! is offline
post #3 of 24 (permalink) Old 11-17-2016, 07:33 PM
Alfa 164 and 3.0 Milano use the same head casting and both have the space for cam driven distributor.
The important thing is to count the teeth on the gear on the oil drive, and count the teeth on the gear that sits on the oil pump shaft. I don't remember the numbers offhand but they are on this site.
Also at the back of the head is nipple that goes to the heater core. Pretty sure that is different from Milano to 164.
Finally statistically you are way more likely to have 164 heads. They made many more 164's than Verde's.
It's very important to get the oil drive gears correct, low oil pressure is the result if you don't.
Bye
Milanoguy is offline
post #4 of 24 (permalink) Old 11-17-2016, 10:39 PM
Alfaguy35's Avatar
Correct oil pump drive gear
Bye
But more important then that is is the 164 drives the oil pump at some speed less than half of engine RPM which will mean the distributor is being driven at the wrong speed so you'll have incorrect timing.
Wes
Winner 24 Hours of Lemons, Finally
Alfaguy35 is offline
post #5 of 24 (permalink) Old 11-18-2016, 05:26 AM Thread Starter
I am trying to find the tooth count but as of this writing have not been able to. I am thinking it is a Milano head as it came with the block off plate. Couple that with Larry sending me the Milano drive gear and sprocket I should be fine. I think!!
DOM! is offline
post #6 of 24 (permalink) Old 11-18-2016, 06:11 AM
kredden's Avatar
That does not look like a OEM block off plate to me. Here is a detailed writeup I did years ago when I was preparing to drop a 164 engine into my Verde. It points out the stuff I had to change which might give you some clue to what you have:
Alfa Milano Registry - Verde Rebuild Finishing Up
Kevin
Milano registry custodian(
kredden is offline
post #7 of 24 (permalink) Old 11-18-2016, 06:25 AM
Richard Jemison
Alfar7's Avatar
Oil pump speed
Actually it drives it faster, an accomodation to have adequate oil pressure due to the oil squirters in the 164 engines.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #8 of 24 (permalink) Old 11-18-2016, 07:13 AM Thread Starter
Kevin
Kevin-
Funny I read that this morning in my efforts to get this straightened out.
Dom
DOM! is offline
post #9 of 24 (permalink) Old 11-18-2016, 09:53 AM
racingswim2006's Avatar
Looks like an OEM block off plate to me...
Rob
racingswim2006 is offline
post #10 of 24 (permalink) Old 11-18-2016, 09:53 AM
Also, you can measure the heater hose fitting on the cylinder head to suggest which car they originally came from. I seem to remember 1/2" for Verde, and 3/4" for 164. IT can be changed, but it's usually stuck in there pretty well.
And...one more thing: the heads seem to have the "crosshatch" pattern visible from its casting mold. I've only ever seen that on 164 3.0 heads.
Rob
post #11 of 24 (permalink) Old 11-18-2016, 10:18 AM
Alfisto Steve's Avatar
TSB 01.92.02 Alfa V6 12v aux shaft drive and oil pump driven driven gear Sets Info
Be advised early non-164S model engine heads, that is early 164B/164L models without oil coolers, did not have oil squirters or the faster spinning oil pump gears.
Early 164B/L engines have same gears on aux shaft and oil pump as GTV6 and Milano engines. They are matched sets you can not mix and match gears.
Refer to TSB 01.92.02 Auxiliary Drive Gear Sets all 2.5 and 3.0 Engines
Early gears 10 tooth aux shaft drive brass gear 60507412 and 60523313 steel 15 tooth oil pump driven gear GTV6, Milano 2.5 and 3.0 and 164 base and L up to 07/90 production.
Note even with that being said the 2.5 engine have different aux shaft and pulley, too.
Later style gear sets used on all 164S engines and later Base and L engines 08/90 production onwards.
14 tooth brass 60559666 aux shaft drive gear and 15 tooth steel 6059665 oil pump gear. This later 15 tooth gear will not mesh with early 10 tooth brass gear.
Note: Aux shaft, and aux shaft pulley same on Verde 3.0L and all 12v 164 engines.
Virginia Beach, VA
My Maintenance Sticky:
Daily drivers: USA models - 1991 164S Black Beauty II ALFISTO;
Daughter's current ride: BB1 my 164L and Her Granddads 2002 Ford Taurus is back up.
New parts hauler but not car hauler 2004 Jeep Grand Cherokee Overland 4.7L H.O. V-8
Needing TLC non-blackbeast the 93 164L
Alfisto Steve is offline
post #12 of 24 (permalink) Old 11-18-2016, 10:19 AM
kredden's Avatar
You are right, I didn't zoom the picture when I was looking at it and the stain on it made it look like it had a hole in it (to me anyway!). After zooming I saw that yes it does look like a stock one.
Kevin
kredden is offline
post #13 of 24 (permalink) Old 11-18-2016, 10:28 AM
Kevin
I had to look twice too, because OEM ones I've seen are usually rusty!
Rob
post #14 of 24 (permalink) Old 11-18-2016, 10:32 AM
Kevin
That blank off plate on L/H (front head on 164)is used on 3.0L Verde heads but removed on 164 head so cam driven distributor can be installed. All 164 front head cams have notch on end to drive dizzy.
Virginia Beach, VA
post #15 of 24 (permalink) Old 11-18-2016, 10:58 AM Thread Starter
I guess I will be counting the teeth later. Thanks gents
DOM! is offline
Replace with
