Wilwood brake proportioning valve - Alfa Romeo Bulletin Board & Forums
post #1 of 23 (permalink) Old 11-16-2013, 11:41 AM Thread Starter
comancheflyer's Avatar
I was disappointed in the braking action of my 89' non-abs Milano and decided to investigate. It has plenty of pedal, but the binders just don't haul it down as fast as it should, and the right front seems to lock up, but not the left. New Repco brake pads did no better. The stock proportioning valve was seeping fluid, so I looked for a new replacement only to find that they are no longer available. With nothing to loose, I decided to take it apart to see if something was amiss inside. Everything looked fine, so I put it back together and re-installed and re-bled the brakes. Instead of it seeping fluid, now it pretty much just drains fluid on the floor and brake action is still poor. I'm kind of confused on how this thing works also. The right front brake goes directly to the master cylinder where as the left front goes through the valve first and then to the wheel. The rear goes through the valve and then to the rear wheels.
So I decided to go with a adjustable Wilwood unit and see what happens. It mounted easily with just a little tweeking of the stock brake lines. Now both the front brakes lines mount directly to the front circuit of the master cylinder, and the rear circuit passes through the Wilwood unit and then to the rear wheels.
After a couple of test stops, and setting the bias more towards the rear wheels, I believe it has improved the braking action considerably of my Milano.
In hind sight, I should have done some measurements to back up my seat of the pants feeling - but it's too late now.
60' PA-24 Comanche
61' Giulietta Spider
69' 1750 Boat tail
73' 911T
89' Milano Gold
90' Graduate Spider
comancheflyer is offline
post #2 of 23 (permalink) Old 11-16-2013, 01:31 PM
shiny_car's Avatar
Indeed, seems like the proportioning valve was faulty. I have seen them available new, but you have to search around, and they are not that cheap.
Alfa Romeo, Fiat and Lancia Brake Proportioning Valves
You can also try googling with the part number.
But, seems you've found a solution to suit you. I'm always mindful, though, if the chances of locking up the rears in the wet when going around a corner (for example); don't give yourself a fright!
Good job.
2009 159SW Ti 3.2 Q4 . Alfa Red - Black | 2006 GT 3.2 . Kyalami Black - Red
1994 155 2.0 8V TS . Gunmetal Grey - Grey | 1989 75 3.0 . Alfa Red - Grey
shiny_car is offline
post #3 of 23 (permalink) Old 11-16-2013, 01:59 PM
racingswim2006's Avatar
I have been using a Wilwood unit like this for years on my 86 GTV6 (which used the same proportioning valve as the Milano). My car also has a residual pressure fitting for the rear brakes (2 psi) and the result is a very firm very high pedal.
Rob
racingswim2006 is offline
post #4 of 23 (permalink) Old 11-16-2013, 06:39 PM
Thank you for posting this! I've switched from ABS to non-ABS on my Verde project. I've been hunting for a setup like this because the same exact thing happened with me. OEM proportioning valve leaked and I've been doing a million other things. I'm definately going to try this Wilwood system out. Thank you!
MDmilano88 is offline
post #5 of 23 (permalink) Old 11-16-2013, 06:41 PM
Is there anyway you can post or get me more pictures of this set up? Seems dark and unclear where exactly all the lines are going.
post #6 of 23 (permalink) Old 11-17-2013, 10:56 AM Thread Starter
Maybe these are clearer pictures of the installation. It was pretty straight forward installing the valve. Remove the old valve. Carefully re-bend the left front brake line into a 90 degree bend and attach to front outlet of master cylinder. Carefully re-bend rear brake line so that it connects to the outlet port of the Wilwood valve. Use one of the left over short lines to attach the rear port on the master to the inlet port of the new valve. Tubing bender and patience is recommended to make nice gentle bends.
60' PA-24 Comanche
69' 1750 Boat tail
73' 911T
89' Milano Gold
90' Graduate Spider
post #7 of 23 (permalink) Old 11-17-2013, 12:52 PM
Excellent! I will be doing this soon. Thank you for more pictures and clearer explanation!
post #8 of 23 (permalink) Old 04-03-2015, 12:21 PM
1992 alfa romeo 164s brake proportioning valve
I am currently looking for a proportioning valve for a 1992 alfa romeo 164s I noticed that it is mounted under the vehicle between the rear wheels. is that the valve or just a block to separate the rear brake lines please need help figuring this out. the vehicle is leaking brake fluid from this part.
vinnyny65 is offline
post #9 of 23 (permalink) Old 04-03-2015, 12:40 PM
Bored Member
jc96's Avatar
t's the valve. requires a specific instal process vinny. ciao jc
Maintaining my tenuous strain on reality.
89 164 2l Twin Spark, 2011 Tonka Dump
Recently added: an 89 75 (Milano) 1.6 litre w/44K on the klok.
Past loves:
79 Alfetta GTV w/Spica, my 1st Alfa
An 88 Graduate. Not really love but interesting nonetheless.
A 68 BMW 1602 - man do I regret letting that one go!
79 Scirroco, ex plowed into an illegally parked house with it...
jc96 is offline
post #10 of 23 (permalink) Old 04-03-2015, 06:24 PM
Nice!
I went with a new factory one, but I hadn't considered this. Might want to get some heat reflective shielding for it though. Everything gets really hot there, being so close to the exh. manifold.
Darth Verde is offline
post #11 of 23 (permalink) Old 04-25-2015, 12:58 PM
cmilano's Avatar
Does that willwood unit have the correct thread fitting size to bolt right on to our brake lines? I have a russel proportion valve from amazon but the thread is 1/8NPT so now i either have to find some adapters or install new fittings and flare.
cmilano is offline
post #12 of 23 (permalink) Old 04-29-2015, 03:19 PM
steveh29's Avatar
Yes, Wilwood makes the correct metric part with the appropriate flares. I have on on my GTV6. I think it's this one but can doublecheck my part number when I get home if you like.
Wilwood High-Performance Disc Brakes - MasterCylinder No: 260-12627
Steve
1986 GTV6 3.0 - No 2nd gear crunch.... yet
steveh29 is offline
post #13 of 23 (permalink) Old 04-29-2015, 07:25 PM
cmilano's Avatar
Should have got that one to begin with. I ended up installing standard fittings and flares to fit the valve I bought.
cmilano is offline
post #14 of 23 (permalink) Old 11-07-2015, 03:23 PM
Gubi's Avatar
Just did this modification due to a leaking original proportioning valve. Thanks to Comancheflyer for the details and pics. Took a bunch of careful bending but wasn't too bad to get it in there.
My brake pressure gauge is somewhat suspect, but I was getting about 800 PSI at the rear brakes with the OEM valve. The Wiwood valve screwed all the way out gave me about 750, and each turn was approximately +50 PSI so I gave it about two turns in to start. Seems to be working okay, but I'm curious how others have theirs adjusted?
1991 Spider
Gubi is offline
post #15 of 23 (permalink) Old 11-07-2015, 05:05 PM
Are you guys locking up your fronts and therefore applying more pressure to the rear?
85 GTV6 3L
alfaparticle is offline
Replace with
