Speedometer amplifier - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 55 (permalink) Old 10-12-2013, 06:15 PM Thread Starter
It Works!
Everything is installed in my GTV6 and it works. I have attached a schematic. It is more relevant to GTV6 so I will post a link to it from the GTV6 forum.
85 GTV6 3L
alfaparticle is offline
post #17 of 55 (permalink) Old 10-28-2013, 07:39 AM
Alfaguy35's Avatar
Connector
Originally Posted by alfaparticle View Post
I would like to buy the connector from the Milano harness that connects to the output connector of the amplifier. Please contact me if you have one.
Thanks.
Ed,
Are you still looking for a connector? I was at P-n-P getting a transaxle yesterday and grabbed the connector for you. Let me know.
Wes
Winner 24 Hours of Lemons, Finally
Alfaguy35 is offline
post #18 of 55 (permalink) Old 10-28-2013, 09:03 AM Thread Starter
Yes, I would like the connector. I am using a modified trailer lighting connector and the correct one would be a big improvement. Let me know the shipping cost in a PM and I will send you my address.
THANKS!
85 GTV6 3L
post #19 of 55 (permalink) Old 01-31-2014, 10:35 AM
gtvpete's Avatar
Would like to revive this thread:
I have recently put a Platinum transaxle in my Verde so now the speedo reads about 15% high. Got a Dakota Digital SGI 5C and asked my mechanic to spend a few hours on it, but he had no success.
Wondering if anyone has addressed this particular combination and can share details on how it was hooked up?
Many thanks in advance,
Peter
gtvpete is offline
post #20 of 55 (permalink) Old 01-31-2014, 10:40 AM
kredden's Avatar
I have one sitting on the bench waiting to go in for this same setup. I got it working in my '86 GTV6 and was assuming that the wiring would be the same (I'm using a Verde sensor and amplifier in the GTV6), but just haven't gotten around to wiring it up yet. From what I remember on the GTV6 is was pretty simple.
Kevin
Milano registry custodian(
kredden is offline
post #21 of 55 (permalink) Old 01-31-2014, 10:49 AM
kredden's Avatar
I did find some pics that I took of what I did on the GTV6 a while after I had done it when I was contemplating putting the one into the Verde (but didn't get around to it). The pictures are truly awful quality and somewhat out of focus but I can send the full res ones to you in e-mail if it would help. Don't expect much! PM me with your e-mail address if interested.
If I posted them up here I'd have to downsize them and they'd be even worse...
Kevin
kredden is offline
post #22 of 55 (permalink) Old 01-31-2014, 11:03 AM
gtvpete's Avatar
To expand a bit on my original question, the SGI 5 was hooked up both to the Sender output, and to the Amplifier Box output, and did not recognize an input signal in either configuration (steady green light). This is as far as we got.
gtvpete is offline
post #23 of 55 (permalink) Old 04-29-2014, 07:31 PM
Anto9931's Avatar
Peter
GTVPETE,
This happened to me as well. I put the speedo cluster from a 2.5 and that solved the issue. It appears all other components are the same, but you need a Verde speedo with a verde TA and a 2.5 speedo with the others.
Anto9931 is offline
post #24 of 55 (permalink) Old 04-29-2014, 10:06 PM
jazig.k's Avatar
If you change out gearbox, match the box with the amp an cluster you took the car from. I remember reading it in the v6 performance manual by jim k.
I put a Ts box in my 3lt, just changed the clusters and amps between them and its fine. Speedo pick up in the gearbox doesn't matter, I used 3lt pickup with all Ts stuff in my 3lt and it seems to read fine (revs at 100kph). I'll find out for sure next week on the road when I get back from holidays.
jazig.k is offline
post #25 of 55 (permalink) Old 04-29-2014, 10:08 PM
jazig.k's Avatar
Doesn't help people putting 75 boxes into gtv's though...
jazig.k is offline
post #26 of 55 (permalink) Old 04-30-2014, 06:11 AM Thread Starter
That is covered in post #16.
85 GTV6 3L
post #27 of 55 (permalink) Old 04-30-2014, 09:42 AM
gtvpete's Avatar
Adding to this from the above comments and my former questions:
The above comment is not correct, at least not in my case. In the end, using Ed's diagram as a starting point for the Dakota Digital , i was able to get it all to work accurately. Going from memory, Output 3 worked, with a minor change to the dip switch position from the supplied diagram. Which means, you *can* install a Platinum TA in a Verde, and keep the Verde speedo and amplifier box.
gtvpete is offline
post #28 of 55 (permalink) Old 05-05-2014, 07:41 AM
kredden's Avatar
I finally got around to installing the Dakota Digital SGI-5 I bought a while back. I have a platinum tranny in my Verde so the speedo was off. I did a write up with pictures on what I did and put it on my website:
Alfa Milano Registry - Speedo Fix Using Dakota Digital SGI-5
I ended up using dip switch settings: 1-on, 2-off, 3-off, 4-on. I also chose to use the GND coming in on the speedo wire instead of a local ground. See my site for more details.
Kevin
kredden is offline
post #29 of 55 (permalink) Old 10-24-2014, 03:21 AM
Alfetta GTV's Avatar
Compliments for your thread, Alfaparticle!
I did not understand one thing.
Installing a T.S. gearbox into a GTV/GTV6, the Jaeger Amp is essential or can I live without it using only the Dakota Digital SGI-5?
Greetings
Daniele
Alfetta GTV 2.0 1982
Toyota Celica Turbo All Trac 1991
Alfetta GTV is offline
post #30 of 55 (permalink) Old 10-24-2014, 03:51 AM
kredden's Avatar
If the TS box doesn't usually use an amplifier then you shouldn't need it, if that box does use one with he cars it is normally in then you will probably need one.
Kevin
kredden is offline
Replace with
