Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Limited Production (1960-1977)
  #46 (permalink)
Old 05-21-2007, 09:24 PM
180OUT 180OUT is offline
[quote]
Originally Posted by jpv View Post
here is some progress...
I've been removing the engine. But I'm having some dificulties. The engine needs to tilt a bit more to get out but the gearbox interferes with the flywheel.
I think I'm going to lower the gearbox to get the sucker out...
With that kind of engine lift, pulling the motor with the gearbox attached is very hard. If you had a hoist suspended from the roof of your garage you'd be able to get a better angle. With the lift you are using you'll find it's much easier to get the engine out if you remove the gearbox first. It's not that hard to do because the 'box isn't all that heavy. You just get the car up as high as possible on jack-stands, take everything loose, drop the gearbox onto your chest (it won't hurt---trust me) and then roll out from under the car.
'70, 1750GTV, 2nd series
  #47 (permalink)
Old 05-26-2007, 12:28 PM
sndesign sndesign is offline
You can try jacking up the rear of the car as high as possible,
this gives you more tilt angle to get it out with the gear box attached.
Otherwise you will need help to push down on the back of the motor
as you pull from the (top) front.
Good luck
sndesign
1966 Duetto
1971 GTV
2005 Lotus Elise
Former
1972 Spider
1974 Spider
1969 GTV
1969 Berlina
1973 Berlina
  #48 (permalink)
Old 06-28-2007, 09:06 PM
magaoidh magaoidh is offline
What are the latest developments on your car JPV?I am following with great interest.
  #49 (permalink)
Old 07-13-2007, 05:59 AM
jpv's Avatar
jpv jpv is offline
Hello!
I've been busy lately so the car hasn't got a lot of attention. But last night I've got around to get the engine and gearbox out.
As sndesign sugested I jacked up the rear of the car and it helped but the engine still was a bit stuck. I putted a jack under the sump with the engine already hoisted and pushed the car down. Only then it came out. It was stuck only by a thread! I don't know how am I going to put it back there again without scratching the paint work though...
Then I turned the attention to the gearbox. I removed it with the trasmission shaft attatched.
The clutch servo gave me a lot of trouble because it was completely seized. The only way was to remove the flexible fluid tube and leave the servo on the gearbox.
After all was loose I just pulled it out of the car...
It's out!
Without the engine it's easier to see the condition of the body.
The front panel and the lower front member are very corroded. They are going to need some work...
Abraēos!
Joćo Vale
1969 Alfa Romeo GT 1300 Junior
1972 Alfa Romeo 2000 GT Veloce
1976 Porsche 924
1991 Mazda Miata MX5
  #50 (permalink)
Old 07-13-2007, 03:08 PM
Mate, you are very brave to do a Junior Z resto. You have most of the Zagato parts? The door trims and the seats may be hard to get???
  #51 (permalink)
Old 07-13-2007, 05:00 PM
Its Out
Way to go !, It's like a metal baby popped out.
Did you do it all by yourself, sometimes the last wiggle is best with a helper.
If you have to put it back in solo, you might want to put the engine in and the trans in as two steps, just make sure to match up the engine and trans on the ground to line everything up, then have at it.
sndesign
1966 Duetto
1971 GTV
2005 Lotus Elise
Former
1972 Spider
1974 Spider
1969 GTV
1969 Berlina
1973 Berlina
  #52 (permalink)
Old 07-15-2007, 05:03 PM
jpv's Avatar
jpv jpv is offline
Hi all!
No, I didn't do this alone. I had help from my dad.
I'm still missing the seats and some minor details. I will try to gather them until the end of this year...
I know that it will be almost impossible to find a set of original seats but I have a pair if GTV2000 seats that will take their place until I find an original set...
I intend to remove the wiring harness and fluid pipes tomorrow night. I'll post more photos of the work soon...
Best regards!
Joćo Vale
1976 Porsche 924
  #53 (permalink)
Old 07-18-2007, 07:04 PM
jpv's Avatar
jpv jpv is offline
More work done!
I had to remove the servo so I could get better access to the wiring harness.
I loosened all the wiring harness in the engine bay and passed it to the cockpit.
This wiring is a lot more complicated than the ones I'm used to on my Bertone Alfas. It doesn't have easy connectors so I have to mark each wire so I'll now how to get it back together... A major PITA...
After removing the harness I started to remove the electrical components. I started on the wiper system. I had to remove the cover that was a bit stuck and rusted but all worked out well...
Found a new hole to repair...
Tomorrow I'm going to remove the heater system that is filled with tree leafs. On the other hand it's in very good shape. It's the best heater I've found on Alfas! The plastic case is impecable!!!
Joćo Vale
1976 Porsche 924
  #54 (permalink)
Old 07-18-2007, 09:58 PM
Wow, mate you are regular martyr!!!
  #55 (permalink)
Old 07-19-2007, 07:55 AM
Subtle Subtle is offline
Director BC Chapter SNO
Worthwhile and interesting project
1962 Giulietta Spider: Graphite Grey/red; "Tuned" 2L.
1993 Subaru Legacy Turbo Wagon(200 whp).
