Old 07-14-2005, 11:33 PM
Montreal; race to make it to Monterey
The engine and trans are finished, not in the car until at least the front body work is done.
Larry
Old 07-14-2005, 11:36 PM
Trans with .79 overdrive 5th
Larry
Old 07-16-2005, 05:35 PM
Send a message via AIM to 81gtv6 Send a message via Yahoo to 81gtv6
Sweet mother of all things alfa!!!
Old 07-17-2005, 07:22 PM
Great to see the engine together
I hope you get it back in the car and all running in time.
What size did you get your throttle bodies out to? Mine were CNC’ed to 40mm at the butterfly tapering up to 38 up the top. (From memory standard is 32mm to 35mm or 36mm)
If you are running the engine hard for a while it will run hot, you can help it a bit by removing the mesh behind the heart grill if it's still there.
Also did you get my Alfa BB Private Message about your pistons?
Regards
Phil.
1975 Montreal - Race prepared... Mean and Green.
1988 75 2.0 TS - Daily Driver.
1989 75 2.0 TS - A bargin I couldn't turn down.
Old 07-18-2005, 12:33 PM
The throttle bodies have 35mm butterflies stock. I bored out the castings to be 35 straight through, they used to neck down to 28mm. Shafts were profiled also, gaining a 28 percent overall airflow increase. Even a 2.0 pulls a 32mm stock so for the street 35mm should be fine. I sent you a PM about the pistons, did you get it?
Larry
Larry
Old 07-18-2005, 02:06 PM
Chatis's Avatar
You and me both
Larry, like you I am racing to make it Monterrey. I am optimistic. If all goes well we will see you there!
Chatis
[COLOR=DarkSlateGray]1974 2000 GTV - Silver - Gone 11/05/2007[/COLOR] [URL=http://www.74argtv.com][I]www.74ARGTV.com[/I][/URL]
[COLOR=MediumTurquoise]1960 Austin Healey Frogeye [/COLOR]
[COLOR=Red]1971 GTV 1750 - Red [/COLOR] [COLOR=Gray](no longer) [/COLOR]
2003 Audi A4 3l
Old 07-19-2005, 06:44 AM
Keven's Avatar
What intake are you using? its obviously not the Spica.
Very clean conversion to FI, great work!!
1978 Spider sold in 1996
Old 07-19-2005, 04:18 PM
Montreal Pistons
Hi Larry no I didn't get the message, please email to montreal@paradise.net.nz.
Please let me know if I can assist in any way (perhaps even give you a table view of our fuel map so you have something to plug in and start with)
Regards
Phil.
Old 07-25-2005, 12:46 AM
twoliterlover's Avatar
Larry, Your transmission pieces and mine made a good combination. I bought a couple bearings and seals. However, Tom locked up the rear end when the pinion bearing siezed. Have you a standared bearing part number -- not Alfa, I mean Fafner, New Departure, Timken, etc.? Bearings are not so sacred that a good American bearing manufacturer can't come up with identical as European through cross referencing and dimension checks. P.S. I have had no responses, so I suspect you are not coming to national convention in Seattle. Jay@alfanut.com in Seattle.
Old 07-25-2005, 10:35 AM
I got your message, called but no answer, thanks for the great offer, but I am trying to make Monterey. With the new boy just not enougn time to do everything. I replaced all my diffential bearings a few years ago.
Timken,
small pinion bearing HM89448
small race HM89410
large pinion bearing HM801346X
large race HM801310
I didn't write down the carrier bearing #'s they are not unusual.
Mine was a little noisy, new bearings and a reset of pinion depth, and reset of carrier preload, helped alot. Diff seized, are the ring and pinion still good? Have a good time at the Convention.
Larry
ALFA PARTS EXCHANGE
Larry
Old 08-16-2005, 11:22 PM
Larry,
what (if any) modifications did you have to do to the intake manifolds to fit the EFI injectors, also, what kind of injectors are you using to get this to work properly
Mad Scientist
AIM: Crucox
Old 08-18-2005, 12:29 AM
The Spica injectors thread directly into montreal heads, those holes where opened up to accept Bosch injectors. The intake manifolds are just 4 dry throttle bodies( 2 butterflies per) that bolt right to the heads. They have been bored out a little. I am using an Electromotive system, can program ign timing and no more dist.
Larry
Old 08-18-2005, 09:02 AM
Larry you are my hero.
you'll hear from me in the near future
Mad Scientist
AIM: Crucox
