Reach for 5th - Alfa Romeo Bulletin Board & Forums
Old 02-16-2005, 12:57 PM
Reach for 5th
I bought a 1300 GT jnr about a year ago and have mostly been stripping it down to be painted. But before I started, I drove it through the summer months and found that the reach for 5th made long trips painful. I saw a web page of a Dutchman and his 105, who had mounted a secondary pivoted gear stick with a connecting rod to the cut down original. I was wondering if anyone else, suffering the same problem, had come up with any solutions.
Old 02-16-2005, 06:17 PM
evanbottcher's Avatar
Here's a link to Mike Valant's remote shifter - http://engr.smu.edu/rcam/cpm3v/shifter/shifter1.htm
'06 Alfa 159 2.4 JTDm / '90 Alfa 75 TS / '77 Alfasud Ti / '68 1750 GTV (resto project)
Visit 'Slow and Fun' - my Alfa journal
Old 02-16-2005, 08:39 PM
genericwood's Avatar
My race car has a remote shifter similar to Valants. But if the reach for 5th is the only problem, I'd be tempted to just bend the shift lever an inch or so. I did this the other direction on my Giulietta to give more room for my knee between the steering wheel and 2nd gear! I have long arms so the reach for 5th isn't too bad. Oh wait a minute, it doesn't have a 5th!
Erik
Old 02-16-2005, 09:04 PM
Alex Csank's Avatar
Send a message via Skype™ to Alex Csank
There is some adjustment that can be made to the Alfa 105 gear lever. All you have to do is remove all the boots (outer, inner and rubber seal) and then you will see that at the base of the lever, there is a bolt and nut arrangement at the front side of the base of the lever. Loosen the nut and then bring the lever a bit more toward the driver. Re-tighten and try running up and down the gears. I'm pretty sure that you will find it to be a big improvement.
The remote levers are great for racing, but for a street car, there should not be a problem with the stock lever.
Cheers,
Cheers,
Alex Csank
Bianco 1985 GTV6
AROC USA Board Member
A.O.N.E., St. Louis & Capital Chapter AROC member
Member of the Alfa Romeo Club of Canada (ARCC), FIAT Alfa Romeo Quebec and Scuderia Non-Originale
alfaromeodriveralex@gmail.com
(514) 771-9513
Old 02-17-2005, 02:55 AM
beatle_bayly's Avatar
I have no problem at all in 5th ! 1st is a bit of a stretch though.
Beatle
'85 Alfa 90 NSW Oztraya
Old 02-17-2005, 10:48 AM
Cheers for the help, I'll try adjusting the gear stick first. However I have long legs and arms not long enough, so a remote lever might me more comfortable and I've never seen one in the UK. I don't know if LH and RH gear boxes are the same, but the travel into fifth seems a lot further than first or third. Give it two weeks and I'll have it back and can explore the adjustment idea.
Old 03-06-2007, 08:56 AM
Short shifter
Thanks for all the useful and historical info on this topic. This sort of thing is the best reason I can think of for this forum.
I just bought the car in the photos attached, a GTjr/GTA replica/TS conversion, and the short shifter was in place. I've removed it, as I've been waving the magic Alfa gearbox wand in the more than 40 cars I've owned in the past 40 years, and am too set in my ways to learn how to shift an Alfa with something else.
Sfourza
Old 03-06-2007, 12:49 PM
Sfourza, I sent you a private message. Please check when you get a chance.
Erik
Old 03-06-2007, 02:07 PM
tek's Avatar
tek tek is offline
Hmmm, another $10,000 or so and my junior could look like that, though I am sure it won't run like that one. Very pretty interior.
Tim
'67 GSGTV-Q (1975)
'69 GT 1300 Junior (current)
'66 Mustang Coupe (current)
Old 03-07-2007, 07:14 AM
SFOURZA,
Where are you located?
That car was here in Richmond several years ago when it got it's twin spark, interior, and shifter transplant.
Ed
Old 03-07-2007, 08:15 AM
geh458's Avatar
HaHaHa....Very funny....If your steering wheel wasn't on the wrong side you wouldn't have this problem.
Gifford
'72 Super --> SOLD, '67 GTV --> SOLD
Old 03-08-2007, 04:04 PM
I am confused. If Doc what's car is a RHD then 5th gear is the closest to him. If it is a LHD, even with the shaft turned through its maximum radial travel away from th driver, it is still close enough to easily reach from the drivers seat as the whole positioning of the driver/gearchange is biased to that side. Is there something about the car which is not standard?
Stuart
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
