Old 07-01-2008, 10:10 AM
howieb4's Avatar
howieb4 howieb4 is offline
Broken bushing
I am a bit embarrassed to say that I know [i]bupkiss[i] about suspensions, but I do know enough to say that I have a broken bushing on my rear sway bar. I am assuming I need to replace them in pairs to keep them at the same wear pattern, but do I need special tools to put new ones in, and pull the old ones out? I've seen a few posts about bushing replacement but none really give the step-by-step instructions that I am looking for. Thanks
Old 07-01-2008, 12:17 PM
Trav Trav is offline
Are we looking up at the rear bar drivers side? It looks like a poly bushing (yellow) that might have the outer half missing??
It can be tricky to keep these end links attached to the bar as they are a slip fit. (at least my 69) IF it is a two piecs bushing the outer half probably fell out. The stock bushing is one piece and press fits in. It's an easy fix.
Get new bushings, tops or tops and bottoms. Remove the end links, take them to a mechanice and have the new bushings pressed in.
Replace the end links.
Someone else might be able to ID the yellow bushings and chime in as to whether they are one or two piece. good luck
Trav
1969 1750 Spider
1971 1750 GTV
Old 07-01-2008, 01:31 PM
howieb4's Avatar
It is the driver's side. Here's a shot of the good side still together. I sent the photo to IAP and they said it wasn't their's since they don't sell yellow bushings. The catalog I have from them clearly shows yellow poly bushings??!
Old 07-02-2008, 12:59 AM
canberraphil canberraphil is offline
I had my sway bar bushes replaced last week (after about 3 months of trying to find the source of that f@#ing rattle from the boot!) My alfa mechanic doesn't speak the best english but the message I got from him is that there are rubber "slip fit" ones and other ones that have a screw or bolt that keeps them attached. I opted for the screw type. I'll post a pic when I have time. I don't know much about suspension either but the metal sleve on your bush suggests to me that it is not a slip on, but the other kind in which case you may have a bit missing.
Old 07-02-2008, 06:50 PM
Manx's Avatar
Manx Manx is offline
Had a similar problem myself. This thread might give you some additional pointers.
[FONT=Trebuchet MS]Land Rover - the daily drive[/FONT]
[FONT=Trebuchet MS]1974 GTV 2000 - current[/FONT]
[FONT=Trebuchet MS]1990 75 Twinspark - the donor[/FONT]
[FONT=Trebuchet MS]1988 33[/FONT]
[FONT=Trebuchet MS]1981 Sud ti Cloverleaf[/FONT]
[FONT=Trebuchet MS]1979 Sud[/FONT]
Old 07-03-2008, 03:14 PM
Mound Dawg's Avatar
Mound Dawg Mound Dawg is offline
The bushes are supposed to slide on then have the end of the bar peened over to stop them slipping off. Very possibly the dumbest method of location ever thought up. A common trick on the front bar is to drill and tap the end to take a bolt and washer. Not quite so easy on the rear bar because it's more like a piece of bent wire than a "bar".
From the pictures you've posted, it does look like a polyflex bush that's lost it's outer half. Looking at the picture of the "good" side, I think the reason is that the bush is too thick for the bar end so that the outside isn't located properly. You should be able to see the end of the bar protruding from the centre metal part of the bush.
To be honest, I'd go back to stock bushes for the rear, they're so small that there's very little rubber to cause flex so the poly jobs won't have much benefit anyway, certainly they won't in the case of yours as the bush looks like it's only pushed on half way.
Stock bushes are cheap, or even cheaper, ditch the rear bar completely. It's so tiny that it doesn't do much anyway!
You can press stock bushes into the drop arms using a bench vice. Peening over the end of the bar is a bit less of a giggle though.
Jim Spackman, Cardiff UK.
1991 Alfa 75 TS LE Veloce, 1970 Fiat 125 [I]Abnormale[/I]
