Been there, done that....
Seriously though. I had the exact same thing happen to my 74' Berlina. I was able to get the box and bellhousing off leaving the engine in the car but it was tight, and the Berlina has a wider transmission tunnel than the GTV.
The next question/ answer to find out is which particular gearbox/bellhousing combination you have.
The earlier gearbox has longer selector shafts that stick through into the bellhousing through a open elongated window. These bell housings have a reversing light switch that simply attaches to the bellhousing via a small sheet metal bracket.
The later gearbox has shorter selector shafts. Consequently the bell housing has no window for them to stick through. The reversing light is a screw in type in this instance.
I have no idea what bellhousing availability is like in the US but it took me six months to track one of any type down and then I had to buy the gearbox that was attached to it at the same time. Maybe consider having your old one welded up by someone with cast aluminium welding experience.
(Photos attached)
Adam
2001 Mazda MX5 - Daily Driver
1948 MGTC - Project 2
1974 Alfa 105 GTV - Project 1
1974 Alfa 105 Berlina - Gone but not forgotten
