06-28-2008, 02:20 AM
getting the steering wheel closer
Does anyone have some words of wisdom on getting the steering wheel of my '73 GTV closer to the driver? I'm all legs and find it tiring to be reaching so far for the wheel. A 2-inch spacer would do me a world of good. I found reference to an Australian outfit called flying performance, but their eBay store is gone. I am thinking of going with a smaller Nardi wheel to alleviate the thigh/steerng wheel/gear lever crowding, but I still would want the wheel closer.
Any tips are much appreciated.
TIA-
-df
06-28-2008, 09:27 AM
Years ago a friend ordered a new steering box/shaft for his GTV and received instead a unit for a Berlina, which was 1-2 inches longer. It did leave a gap between the steering wheel and the clam shell trim, but he loved the closer wheel. Keep in mind that when you switch to a smaller steering wheel, the steering effort goes way up. I spoiled the steering on a TI by going with a cool-looking smaller wheel. I don't recommend it, especially if you have tires wider than stock.
Good luck,
Barry
06-28-2008, 10:08 AM
Originally Posted by dan farmer
DI am thinking of going with a smaller Nardi wheel to alleviate the thigh/steerng wheel/gear lever crowding, but I still would want the wheel closer.
We stock a nice leather Nardi with a deep 80mm dish just for this situation. It really makes a difference in driving position, and it feels great too.
06-28-2008, 03:01 PM
Momo makes spacers which fit their hubs - 12mm and 25mm IIRC, and they come with the required longer fasteners. I use a 12mm on my '87 Spider, simply because the wheel was almost touching the turn signal stalk.
06-28-2008, 04:22 PM
bjfrantz@charte had written:
"...a friend ordered a new steering box/shaft for his GTV and received instead a unit for a Berlina, which was 1-2 inches longer. It did leave a gap between the steering wheel and the clam shell trim, but he loved the closer wheel."
yea, I guess that would work - but, what did that friend do about the cancelling mechanism for the turn signal switch? It would seem that the switch would now be mounted too low on the (new longer) steering column to wrap its spring around the inner shaft. I guess you could cut and weld an extension into the cast aluminum piece that supports the column and provides the mounting holes for the TS switch (as well as the plastic shroud). That would make for a neat installation, but it would require some fabrication. Plus, you need to find a good Berlina box + column.
An easier solution seems to be the one that Kilgore Trout recommened: stack some spacers between the wheel and the hub adapter (assuming the wheel is a Nardi, Momo, or similar), and use longer bolts to sandwich the whole assembly together.
'63 Guilia spider
06-28-2008, 06:33 PM
Think outside to box.
Instead of moving the wheel closer to you, move you closer to the wheel. I had the identical problem with our Spider; arms straight out despite the seatback in full upright. My solution was to raise the rear of the seat by installing 18mm thick spacers between the floor and seatrails and lowering the front by 4mm by removing spacers. Arms are now comfortably bent with the seatback reclined about two inches.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
06-29-2008, 05:08 PM
Shed troglodyte
I have the same problem (tall with long legs) and some years ago replaced the standard Hellebore wheel on my coupe with a deep-dished Nardi similar to the one above but wood-rimmed. Eventually I got over it all and for the sake of originality put the Hellebore back on. Eventually you 'personalise' your driving position so your legs aren't too splayed, you can reach and turn the steering wheel safely and your head isn't rubbing the hood lining. The upshot is that you are the only one that can drive the car and that has to be a bonus.
Chris
Own - 1970 1750 GTV
Want - 1969 Duetto (in addition)
06-29-2008, 07:10 PM
Good questions to which I have no answer. I do not remember any of these issues being a problem. I think everything just came forward without any serious modification needed. I still know the car and will investigate when I can.
Barry
