06-15-2008, 03:54 PM
Long Time Gone
Hello, as many of you can see, I am new to the site. Here's the story:
I was given what I believe to be a '71 GTV 1750 by my grandfather when I graduated high school in 2002. I now have tools and a garage to be able to start working on the car but dont know where to begin!
It has been sitting for 20 or so years. I have no idea what to do or where to begin! I was thinking about removing the spark plugs so there would be no compression and put something in that would maybe lube it up or break away some of the junk?? Just to see if I can get it to turn over, not start, but turn. I am not looking for a race car here but to be able to get it running just enough to make my grandpa happy before his time comes.
Sincerely,
In over his head
06-15-2008, 05:44 PM
First of all, welcome to the board. Next, where are you? If you pull the spark plugs out, change the oil and spray the cylinders down with some WD40, thats a good start. Let the WD40 sit overnight, then put a little motor oil in and let that sit for a while. Then with fresh oil in the engine, you can either pull it through by hand, or try clicking it over with the starter. I'd go by had to start with.
Once you are ready to crank it with the starter you will find out if the fuel pump is good, (it will buzz.) If the gas tank is foul, pull it and get it redone. Replace both fuel filters, drain and fill the coolent (even if you just use reverse osmosis water) and then you should be ready to see if it will fire. A new set of plugs will go a long way, as will a new set of points and a dizzy cap.
Thats what I did with my car that sat for 30 years. It runs like a top.
Once you get it to start, just let it idle, don't rev it, just let it sit there and do its thing. Check for leaks, and after its fully warm, shut it down, check your fluid levels, and go from there. You can gently rev the engine from this point, slowly add throttle, and take it easy. Listen for any bad noises, if you hear something that sounds bad, stop.
Mine smoked and blew acorn pieces and rust out the tail pipe for a long time, eventually it quit doing all the above and is now happy. Yours will smoke like crazy as you have sprayed WD40 and oil into the combustion chamber and it will have to burn off. The smoke should have a blue color to it. White, you have a possible head gasket leak, black, you have a carb/ spica issue (its way rich.)
Post some pictures so we can see what you have.
Good luck,
Will
06-19-2008, 05:58 AM
Thank you! I will post pictures when I get over to the car, thinking this weekend. I cant wait to get started. Should be interesting.
Located in Columbus, OH. We know and are part of an Italian Car club but only a few Alfas! I will be looking into the local clubs around here, now. Again, thank you and I will post what my reply and pictures this weekend.
06-19-2008, 09:03 AM
Congratulation and enjoy! I acquired my '74 GTV in much the same way. An uncle had owned it through the mid-80's, and it was passed on to my grandfather who drove it little (but showed it occasionally) through the '90's. He gave it to me while I was in college, in running condition but needing a little neglected maintenance to make it a safe weekend driver. I have enjoyed the hell out of it for the past 10 years! I had help from a very good Alfa mechanic to put it back into reliable shape, and have learned a lot on my own as well. You will not regret having this car, even more since it has family ties with it.
06-29-2008, 10:27 AM
Got a question... how would one turn the motor over without using the starter? This assumes that the battery is shot and who knows about the other systems. What would one get a big wrench on and then try to turn it?
06-29-2008, 11:22 AM
Long Time Gone
Originally Posted by lowmileage
Thanks, Fred; appreciated --- an opinion we share.
You might also search the bb for members that live near you, there are several active members in the Ohio area, recognizing that Ohio is a big state, who participate on the bb and have been known to help others out in their local area. I believe the Alfa chapter in Ohio is the Ohio Valley Chapter.
Good luck with your adventure, it will bring you cherished memories and most likely make your grandfather very happy and also extremely proud.
Cheryl
(Not an authority nor SME
on anything, just PATSYF)
06-29-2008, 11:33 AM
In the Spiders' nest...
There is an AROC chapter in Columbus, another one in Cincinnati and one in NE Ohio... The folks are very friendly, and very knowledgeable. Have a look at the website Alfa Romeo Owners Club USA | Home and click on "Community" and then "Chapter" for contact information. (Didn't see this thread before... Many of us just got back from the national convention that ended last weekend, June 22nd, in Chicago...)
Best regards,
Enrique
P.S. Sorry, meant to but forgot: Cheryl, Ohio Valley is the Cincinnati chapter. The one in Columbus is the Buckeye Chapter.
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Reason: Added P.S.
