Old 06-03-2008, 06:35 PM
daveydog's Avatar
daveydog daveydog is offline
Want to take the doors off
Here's a couple of shots of the passenger side door hinges. To get the door off the body I reckon I need to take the pin out of the door limiter. Is there any special technique? Of course, then I have 8 hex head screws to remove. Just douse them with Liquid Wrench and start torqueing away? How about the hinge pin? Just tap it out with a drift or is there a special tool? Gotta remember, righty tighty lefty loosey
Thanks all!
Old 06-03-2008, 07:03 PM
rogerspeed's Avatar
rogerspeed rogerspeed is offline
done it, first remove the limit pin (save) then you remove the door with hinge from the body, use a hand impact driver (the kind you strike with a hammer) not air gun. Make sure you support the door as you remove the machine screws, first two screws from the upper hinge, two from the lower, one from the upper, one from the lower and then the last two, one upper and one lower. When I did mine I found it worked well using an extention on the impact tool.
'67 BMW 1600ti/Alpina
And Looking For Another
www.machocheese.com
"just say no to reductionism"
Old 06-03-2008, 07:27 PM
rogerspeed's Avatar
Follow-up, the hinges are aluminum! Once the door with hinge is removed from the car you can then remove the hinge from the door. Centerline sell a pin & bushing kit for renewing the hinge, you will need to press out the pin, I used a large bench vise, be carefull.
www.machocheese.com
Old 06-04-2008, 05:54 AM
daveydog's Avatar
Thanks for the tips rogerspeed! I've already bought the hinge replacement kits from Centerline and will be installing them once the doors are cleaned up. There's a bit of rust and gooey tar/undercoat issues that I'd like to attend to before I send the car in to the body shop for work. And of course, the driver's door has way more play than the passenger side. You gave a really good tip there on removing the screws in a kind of upper and lower crisscross pattern. Thanks again!
Old 06-06-2008, 01:10 PM
green 69 gtv's Avatar
green 69 gtv green 69 gtv is offline
Also, you probably know this but just in case, the main hinge pin comes out from the top of the hinge. BTW, I had a horrible time trying to get it out with the hinge in a vice. I ended up using a drill press (the pin is very soft metal) and carefully drilled until only a very thin cylinder remained of the old pin. This was then easy to tap out without damaging the aluminum. After inspecting the outside of what was left of the old pin, it was so pitted it was no wonder pounding on it hadn't worked.
The replacement kit from centerline is fantastic, although I had to hand sand the flares on the inserts to thin them enough to put the 2 hinge halves back together. Very tight fit. After adding a washer between the car body and bottom hinge at all screw points, the door clicks closed like on a new car
