05-08-2008, 07:58 PM
Okay, here's the update. I connected my grease gun to the caliper fitting and placed a piece of thin plywood between the pistons then began to squeeze. The loose caliper began to creep out but the other wouldn't budge. Finally the loose piston hit the wood while the other piston stayed put not even moving a micron. Finally, the one loose piston came out far enough to begin oozing grease from around it's circumference and the other piston never budged. I removed the piece of wood, but there still wasn't enough clearance for the loose piston to come all the way out. The other piston is firmly stuck and won't budge. What's the next step?
Dale Thomas
1969 1750 GTV (Giallo Ocra)
Summerville, South Carolina
05-08-2008, 08:12 PM
Did you C-Clamp the wood in place?
What's next?
You will need:
* A blast chamber
* A 13hp honda motor
* hydraulic pump(engine driven)
* Hydraulic hose
* Hydraulic oil
Are you regretting calling this the easy as 1 2 3 brake rebuild?
Chris Madden
1974 GTV
05-08-2008, 08:18 PM
Oh its not that hard. Just messy.
If one side is stuck, rebuild the other side, put a C clamp on it to hold it in place. Hook the caliper back up to the brake system and pump away. The other piston will pop out.
Messy and time consuming. But not difficult.
05-09-2008, 07:53 AM
Don't I feel stupid. I missed the C-clamp part. Will give it another go this weekend. The other piston is stuck in just the right spot where the loose piston does not have enough clearance to pop out. Thanks for the tips.
Dale Thomas
05-09-2008, 11:58 AM
Originally Posted by daveydog
Be careful out there fellow Alfa nuts!
And if you just can't be careful, then at least have lot's of ice handy...
not to get too off topic, but reading this reinforces something my dad hammered into me, which ultimately saved my legs. If you take a wheel off, put it under a part of the car so if it falls off the jack, stands etc., it gets the wheel before it gets you. Something like 20 years ago was stuck working on the 330 on a hard pack surface. Not my choice, but had no other options. The car had been sitting there for hours just fine, and then in slow motion it just came at me. I scrambled back as fast as possible, but my legs were still under when it landed on the wheel I'd thrown underneath. That wheel saved my legs and proved once again that father knows best. It's little events like this that'll make you religious about safety.
_________________________
-David '83 GTV6, '67 GTV, '66 Ferrari 330GT
05-11-2008, 07:18 PM
Prior to working on my gal again, I'll put the wheels underneath. Thanks for the safety tips. It just makes sense doesn't it. I'll pass this along to my kids too! The weekend was little too busy for me to work on the brakes again but I did go and buy a set of C-clamps. I'll post more when I get the chance.
Dale Thomas
05-12-2008, 12:38 AM
[quote=Alfajay;544964]Dale:
One of the harder parts of the caliper rebuild operation is getting the pistons out of the calipers. Especially when the seals are hardened and things are dirty/rusty.
The "easiest" way to do it (and "easy" is a relative term here) is to use hydraulic pressure to push them out. With the calipers & brake lines still in place, remove the pads, step on the pedal, and push them part way out. Ideally, once they are most of the way out, you can remove them mechanically (ie. yank them out). Don't use vicegrips though - you'll mar the outside of the pistons.
Compressed air is another solution, though few air compressors generate as much pressure as a brake hydraulic system.
To add to this i would use a small piece of wood in between the pistons before apply the brakes or compressed air, the pistons will come out fast and you don't want them bashing each other.
Rich
05-12-2008, 09:22 AM
When under a car, any car, I use the jack stands, the hydralic jack as back-up touching a support area and always throw the stacked tires under the area I'm working. Good advice your dad gave emerald. I can always buy new wheels but only have one chest or head. Better save than sorry...
