Old 05-03-2008, 10:16 AM
MidLifeCrisis's Avatar
MidLifeCrisis MidLifeCrisis is offline
Ride Height Puzzle
I'm putting my car back together after replacing the clutch and all the bushings in the rear. I have the red IAP spring set, and the car seems to be driving "downhill".
I also noticed that someone before me put a metal spacer on top of the right-rear spring. Without this spacer, the right-rear wheel well is about 1.5 inches lower than the left. I should mention that this is with the fuel tank half-full, and that the battery has been moved to the right-rear in the trunk. I'm hoping this explains the difference and that it's not something more serious, and that possibly the new bushings will help level things out.
I'd like to lower the rear-end about 2 inches but keep it level side-to-side. Can I (should I) cut these springs? It doesn't look like they'd sit in the TA well if I did.
Any recommendations/comments are welcome.
Thanks.
Old 05-03-2008, 05:28 PM
Stachowiak Stachowiak is offline
Member
Hi,
That looks like it's sitting way too high. Did you tighten everything up while the suspension was loaded with the weight of the car, or did you have the car on jack stands when you did it? You don't want any preload on the bushings when sitting on the pavement. Also the IAP red springs should have lowered the whole car. Measure the center of the wheel to the top center of the wheel well opening, and let me know what you get at each wheel. This will give a measurement that is independent of your tire size, and something that you can compare to other members cars. It is normal to have the driver side about 1/2 inch higher. Also, do you have the deeper front spring pad on the passenger side?
Dick Stachowiak
71 GTV
71 Spider
Old 05-03-2008, 08:21 PM
Alfajay's Avatar
Alfajay Alfajay is online now
I agree with Dick Stachowiak when he advises that all through bolts holding the trailing arm bushings need to be tightened while the car is sitting on its tires. However, I disagree with Dick when he says that these springs should lower the car. Well, OK, Dick is right when he says that they SHOULD lower the car. However, in my experience, these stiffer performance springs are often SO stiff that the car ends up sitting higher.
Needing to trim some wire off the coils to obtain the desired ride height is pretty typical. Note that when you shorten a spring, the remaining coils become stiffer in lbs/in terms. Also since the springs aren't directly over the tire contact area there is some geometry involved in calculating how much to trim vs. how much the car will be lowered. Other threads on the BB have addressed these calculations.
The first photo shows what my garage looked like on spring cutting day. I've gotten real good at removing my front springs, trimming them, and reinstalling - my rears came together in one go, but fronts I've futzed with numerous times - cut a little, add a spacer, cut a little more, try a different spacer, etc. etc.
What size tires are you running? Is your car sitting too high or is the o.d. of your tires just too small to fill the wheel wells at normal ride height? The second photo shows my Sprint GT with tires that seem more "chubby" than yours (they're 185-70/14). Yea, I've raised the front a bit since that shot was taken.
'63 Guilia spider
Old 05-03-2008, 11:28 PM
Gary Williams's Avatar
Gary Williams Gary Williams is offline
Here's how my '67 sits with the Alfaholics Fast Road Suspension. My son's '74 has Centerline performance springs and sits at about the same height, without having to cut anything. We both have Falken Azenis 195-60x14 tires. Did you take the spacers out of the spring pans before installing the new springs? Are your springs fully seated in the pans?
Gary Williams
Washington State
'67 GTV
Old 05-04-2008, 05:55 AM
Originally Posted by Stachowiak View Post
Hi,
Dick Stachowiak
71 GTV
71 Spider
Thanks for the response,
The car is still on jackstands. I want to figure out how to correct the height before I put everything back on.
I did measure the height of the rear before taking everything apart - this is 25 inches from the center of the wheel to the wheel well. The left side is about 24 and 3/4 inches... this is with the spacer on top of the spring installed.
I didn't measure the front because I actually had to use spring pan spacers to raise it... I was hitting the pan guard too often. I don't think I want it any lower than it is. Yes, the spring pans in the front are on the correct sides.
Old 05-04-2008, 06:21 AM
Thanks Jay,
I'm running on 175-65/14 tires. The stance of my car looked a lot like the one in your photo before I added spacers to the front spring pans. It still looks to high in the back, and a friend of mine commented on the significant amount of roll he saw when following me once (never felt it from the driver's seat).
I'll probably wind up taking the spacer out of the right-rear and cutting the left-rear spring to level the ride height side-to-side. My concern now is when I cut the spring it will come to a point rather than the flattened last coil it has now... maybe I can heat it and flatten this out a little?
Old 05-04-2008, 06:25 AM
That's the look I'm shooting for...
I only have the one spacer in the right rear to make it sit level from side-to-side. Everything is apart now, but yes, the springs were seated well when the photo was taken.
Old 05-04-2008, 06:29 AM
GTV4EVR's Avatar
GTV4EVR GTV4EVR is offline
Just curious, why are you running tires that are so much smaller than stock. If you like the 65 profile, you should be running 195-65/14 to get close to stock OD.
Ken Lee
Oakville, ON
1973 GTV 2000 - Rowdy (or this one I hope)
Old 05-04-2008, 06:42 AM
I guess I didn't know what size was stock . Looks like I'm also investing in new tires...
Old 05-04-2008, 06:55 AM
GTV4EVR's Avatar
According to the online tire size calculator, it would increase the diameter of your tires by 1 inch. 185-70/14 is the "correct" "modern" size. My 69 GTV came with 165 R 14 Michelin XAS tires.
Ken Lee
Oakville, ON
Old 05-04-2008, 08:50 AM
Alfajay's Avatar
GTV4EVR had written: "If you like the 65 profile, you should be running 195-65/14 to get close to stock OD."
I don't disagree with GTV4EVR's math in calculating the tire diameter. However, keep in mind that these bodies were designed to accommodate skinny tires (155x15 or something) - as you get into lower profile tires, you increase the tire width, and may get interference between the outside of the tire and the rear fenderwell. This is aggreviated when the car is lowered, though stiffer springs & shocks may prevent the body from dropping much.
You can roll the inside edge of the wheelwell to create more clearance. But no, you can't flare the wheelwell - Bertone will send the authorities out to your garage, and confiscate your car if you mess with Giorgetto Giugiaro's perfect design.
MidLifeCrisis had asked: "My concern now is when I cut the spring it will come to a point rather than the flattened last coil it has now"
Most Alfa springs are flattened on one end, and just have a 90 degree cut on the other. Then, the spring pan has a dimple to accommodate the square cut end. So, cutting at an angle to achieve a flattened end isn't necessary. I just grind the raw ends to round them a bit and they're fine.
Keep in mind that with any spring change, you need to drive for a few miles on a bumpy road to settle the springs into the pans - ride height often drops 1/2" or so after the first drive.
'63 Guilia spider
Old 05-04-2008, 09:28 AM
UngaWunga UngaWunga is offline
You can also grind a flat end on the spring. Just don't heat it up too much.
I'd be careful cutting the springs. As said before, cutting the springs increases the spring rate, making them stiffer. If you are already using stiffer springs, this might make it more than desired. Besides, the stance of your car looks OK to me with your smaller tires.
Drive it for a bit, then remeasure.
Old 05-04-2008, 09:42 AM
When you shorten the springs, the axle limit straps also need to be shortened or the springs can come loose in the pans when weight is taken off the rear axle. Driving for a few miles on a bumpy road may resettle the springs, but probably at a cost to the car. I've done that by accident, before realizing the problem; the springs go into the pans with a horribly load CLANG!
I'd still want to know why the car doesn't sit level before cutting any springs. It may be that you have no choice, but my first option would be to go to my friend Terry's alignment shop and have him check out the suspension.
As for tires, the 195-60's fit just fine without clearance issues. While my brakes, engine, suspension, and tranny are Scuderia Non Originale, the body is unrusted, unmolested, Giugiaro penned stock.
Gary Williams
Washington State
'67 GTV
  #14 (permalink)
Old 05-04-2008, 10:25 AM
Thanks guys.
Gary - good tip on the limit straps... I wouldn't have thought of that. I just got new ones so I'll remember to do this before installing them.
My plan is to remove the spacer on the right side and cut the left spring by the same height as the spacer. This should have the effect of lowering the car in the rear slightly while keeping it pretty much level, since the lowering effect of cutting the spring is 1:1 in the rear. I can always cut more later off both if I want it even lower.
BTW, I purchased poly bushings from Performatek for the trunion to diff and trunion to body joints. My trailing arms will have poly bushings in the front and the standard rubber bushings in the rear. My hope is that by lowering the car slightly and replacing all the bushings, some with the stiffer poly, that I will improve the handling on an already fun car.
  #15 (permalink)
Old 05-04-2008, 11:31 AM
GTV4EVR's Avatar
Sorry Jay, from the his Avatar, I thought we were dealing with a GTV 2000. The 1750s and 2000 came with 14 inch wheels. I run 205-60/14 on my 74 GTV with no issues. When the original 165R-14s wore out on my 69 GTV (about 1 year) I switched to 185-70/14s then 195-60/14s and never had any rubbing.
Ken Lee
Oakville, ON
Digg this Post!
