Hello all,
Much to my disappointment, I found out lastnight that I wont be able to use my 1750 gearbox with new 2liter motor. I was planning to reuse my old 69gtv gearbox with a modified 2 liter bellhousing to mate to my new motor. The 1750 bellhousing has a window for the 3 shift forks to poke through. One of these forks also activates the reverse lamps.
I modifed my 2.0 bellhousing by milling a window out for the shiftfork travel. What I didn't relise is untill I pulled the BH of the tranny is that the 1750 window has land around this area to keep the gearbox oil from seeping out. The 2.0 BH dosent have a window so it does with out the landing.
Well my next plan is to find a used 2.0 gearbox and bellhousing just to get the car running. I am wondering if 2.0 gearbox will mate right up to my 1750 driveshaft? I recall looking into changing to a LSD rear axle and remembered you must change the driveshaft also. The 2.0 are larger.
I counted 131 tooth on my ring-gear flywheel. I believe the 72-74 are 130 tooth. What year staters are for the 131 tooth RGear??
regreting build a 2.0liter....should have modified my 1750
davbert
