#31 (permalink)
Old 08-09-2004, 06:39 PM
PSk PSk is offline
BTW: The Alfa specialist I worked for in NZ (during Uni holidays) had a very interesting extra for looking after head gaskets on these motors.
On his own personal car (and where he could with customers) he continued to retorque the head (when cold obviously) about once a week until he could feel that he was not going to get any more, and thus the head and gasket had finally seated. This was a modified motor with a slightly higher compression ratio and he had NOT had the head off for over 2 seasons of racing and cruising.
Thus when I rebuild my 105 engine I will be doing this also until I feel that the nuts will not go any further for that correct tighting torque.
His belief, and now mine, is that the open design of the block, etc. allows the liners and head to move around and thus the tighting torque is not maintained and thus many more goes than just the one retorque is required.
This might be a load of cr@p ... but his car is proof and when he does a head gasket for a customer he retorques the same every time he can ... and they are fine. When you think about how easy these engines are to retorque ... worth doing I think.
  #32 (permalink)
Old 08-10-2004, 01:22 PM
reinspidered reinspidered is offline
But to what torque
Pete,
I can totally understand going after the head gasket all of the time, I think that's a great idea. What torque did he go to or did he just do stock torque? From the way the post reads it seems like he just torqued it as high as he could but I can't see how that'd be good since you could easily get hundreds of pounds with our torque wrench.
Thanks for all of the good advice. Cross your fingers for no leakage, he's got a dead battery now...
\\trent
'72 Citroën DS21 Pallas
'74 ALFA Spider
  #33 (permalink)
Old 08-11-2004, 06:53 PM
PSk PSk is offline
Originally Posted by reinspidered
Pete,
\\trent
'74 ALFA Spider
Oops I was not very clear ... definitely standard torque. He would slacken a little, oil and then retorque. He usually found that he got an extra degree or so of turn with the same torque setting.
He stopped this process when retorquing would not turn the nut any further at all.
