#46 (permalink)
Old 03-19-2008, 06:16 PM
1750GT's Avatar
...in the Garage...
Bill, I contacted them and they replied that they are no longer doing them. I've been mulling over the idea of doing these myself by using the products offered by Alumilite....
Alumilite - How To's
....however if we can get the lens made using a thermoplastic instead of a resin, I believe that this would be much a better way to go (as well as being less time consuming in the end). We could buy just the lens and use Osso's technique to restore our originals.
Rossano
1969 105.51 1750 GT Veloce (restoring)
http://www.alfabb.com/bb/forums/gt-1...storation.html
  #47 (permalink)
Old 03-30-2008, 11:27 AM
116_Veloce's Avatar
Send a message via ICQ to 116_Veloce
Sperimentazioni e Guaranizioni
*BUMP*
I've been checking on the gasket issue and today I made some experiments with EPDM white rubber profile that I was able to source out. It seals good and looks right. I want to check out a silicone rubber cord which should be even better as EPDM extruded rubber is a somewhat porous material.
Here is the result so far:
We're getting closer to a very good finished product.
Screws are also on the way.
Azzurro, e troppo lungo il giorno per me...
  #48 (permalink)
Old 05-12-2008, 06:41 AM
116_Veloce's Avatar
OK, the lenses are finally complete with the correct rectangular profile white gasket. It is a very resilliant silicone rubber, and all lenses will be sold with the gaskets installed.
  #49 (permalink)
Old 05-12-2008, 07:04 AM
Great work! let us know how and when to order. Thank you!!!
Pat Padden
'74 GTV - owned since '92
  #50 (permalink)
Old 05-12-2008, 05:07 PM
116_Veloce's Avatar
I put these periodically on eBay (same nick as on the BB) or contact:
veloce116@gmail.com
  #51 (permalink)
Old 11-06-2009, 03:21 PM
'69 amber side marker lights anyone?
Bump.
Does anyone have a current source for these?
I can almost see the finish line on my project, and wondering about replacing my faded amber side marker lights.
Matt C
1969 GTV, Giallo Ocra
2003 Saab 9-5 Linear wagon
1969 Datsun 1600 Roadster (sold)
  #52 (permalink)
Old 11-06-2009, 04:09 PM
1750GT's Avatar
...in the Garage...
I've been looking for new repro side lens for more than 2 years to no avail. I plan on making resin ones (using Allumilite resin) next year should none become available by then.
Rossano
  #53 (permalink)
Old 11-07-2009, 06:06 AM
GTV-GR's Avatar
dude make the rear ones they r the most pricey
  #54 (permalink)
Old 11-07-2009, 10:15 AM
1750GT's Avatar
...in the Garage...
Rear ones are more readily available used (I have a spare set I picked up last year). The front ones fade badly for some strange reason. In any event, once a mold is made the lens can be made in any color quite easily.....it's not at the top of my to do list at the moment.
Rossano
