Old 02-10-2008, 01:21 AM
Andrew Stevens Andrew Stevens is offline
Location: Perth, Western Australia & Windsor, Berkshire, UK
GTV Headlight gaskets
Hello again from downunder
Starting to assemble my headlights and I wanted to clarify how the rubber 'gaskets' should go. On the high beam lights they appear to go between the backing bowl and the light unit, but it's not so obvious on the main lights, as there is no provision for the high adjuster as fitted to our RHD cars. Any suggestions as to how it should go? I did a search on the board, but couldn't find any reference to them and the parts manual is not clear on it.
Cheers
Andrew
Andrew Stevens
1970 1750GTV
Old 02-10-2008, 03:21 AM
Chris1750's Avatar
Chris1750 Chris1750 is offline
Shed troglodyte
Andrew,
Is this the bit you mean - my old ones (perished & thrown away) fitted around the main headlight reflector in the same manner as for the inner high beams. These new rubbers seem to have the cutout that you are talking about - permits access to the load adjust lever - as well as holes for static beam adjustment. The outer stainless steel ring fits over the top in the same manner as for the inner lights 'trapping' the splash guard, gasket or whatever it's called between the rim of the reflector and the outer ring. All up, it's not a great system, either that or I'm not fitting it correctly ...
Chris
PS: I can photograph it out of the packet if you wish.
Own - 1970 1750 GTV
Want - 1969 Duetto (in addition)
Old 02-10-2008, 03:40 AM
Thanks Chris
The moulding I have doesn' seem to have the cutout, but I happen to have two sets (doubled up a purchase by accident), so I'll check the other ones to see what they are like. I agree that the fit seems rather 'approximate'...but I guess they provide some token weatherproofing.
Andrew Stevens
1970 1750GTV
