  #46 (permalink)
Old 12-10-2007, 12:49 AM
haazed's Avatar
haazed haazed is offline
Thanks stephan for your explanation, this product smells good, but as explain Bertonemorten, it's quite expensive and if it's the better solution perhaps I will invest in this because if you add the high performance 3ohm coil and the cable like purposed by Brits&pieces you add 90€ to have the top quality and the difference is about 100€...
Originally Posted by Bertonemorten View Post
Top product would be a 123 ignition system that could be programmed via a PC.
If only 123Ignition could read this post... They will realize Alfistis need a product like this, but we need it with more possibilities or at less finely finished with advices taken from Alfa pro...
that's really too bad to be so near of the perfect electronic ignition solution...
I want to send them an email for reading this post. what do you think about that ?
  #47 (permalink)
Old 12-10-2007, 01:59 AM
Bertonemorten's Avatar
Bertonemorten Bertonemorten is offline
I think it would be a good idea. I´ve been trying to register in their forum, but I never got a passwort, and there is no email where you can contact them. Sent a fax about 2 months ago, but got no answer...
Best Regards
Morten Svendsen, Rødekro, Denmark
Alfa Romeo 1300 GT Junior 1966
  #48 (permalink)
Old 12-10-2007, 02:23 AM
haazed's Avatar
I will try this : Albertronic
Hope they are open-minded...
Future will tell us...
  #49 (permalink)
Old 12-10-2007, 02:36 AM
haazed's Avatar
It's done. waiting for an answer...
  #50 (permalink)
Old 12-10-2007, 05:00 AM
haazed's Avatar
Getting an answer from what it seems to be the boss of Albertronic : "Thank you, I will read it regularly !"
Rest to wait and see...
  #51 (permalink)
Old 12-10-2007, 09:14 AM
Richard Norris Richard Norris is offline
123 electronic distributor - update!
The 006 tuning curve I mentioned is in Jim Kartalamkis' - tuning book (new edition) "How to Power Tune Alfa Romeo twin cam engines". I will upload a diagram from the book later this week.
Just to let you know that 123 really do listen to customer feedback (not just from the Alfa world but also classic car users generally) - they are already working on & hoping to launch in 2008 an electronic distributor with a USB connection to allow you to do just what some forum members have asked for - one you can programme from your laptop!
This way they will have the unit we currently sell for standard & mildly tuned cars and then a completely adaptable unit for the tuning enthusiast!
Richard Norris
Classic Alfa
London
UK
  #52 (permalink)
Old 12-10-2007, 11:58 AM
alfaparticle alfaparticle is offline
Hi Richard:
Posting that curve will be helpful.
  #53 (permalink)
Old 12-10-2007, 12:35 PM
180OUT 180OUT is offline
Post
Do a search for "distributor curves". Pappajam posted the Shankle modified advance curve about a year ago.
'70, 1750GTV, 2nd series
  #54 (permalink)
Old 12-10-2007, 01:22 PM
I have the Shankle curve. Better than that, I have a Shankle modified distributor with the original documentation from Shankle. It is about to go on ebay. It is the 006 curve that has been a mystery so far.
  #55 (permalink)
Old 12-10-2007, 10:22 PM
Distributor curves
Curves from Papajam
Advance curve
Best Regards
  #56 (permalink)
Old 12-11-2007, 12:30 AM
Curve for modern fuel
Also worth re-stating Jim K's comments from a couple of years ago - Bosch 0231.178.006 distributor curve is more suitable for modern fuel (see attached curve diagram). This curve is found in Position A on the current version of the 123 distributor.
Richard Norris
Classic Alfa
London
UK
  #57 (permalink)
Old 12-11-2007, 04:16 AM
I am running the Bosch 0231.178.006 distributor curve that Richard has posted. The engine is a 2L with 10:1 pistons, CB47 cams, a ported head and Webers with 34 mm venturis. The idle is exceptionally good. It settles immediately at 700 rpm, picks up well and does not ping on 93 octane. But there is definitely a loss of mid range power compared with the Shankle Sport Marelliplex that was in the car until 10 days ago. That is why I want to know about the 006 curve.
2 x 88 Milano Verde's
  #58 (permalink)
Old 12-11-2007, 05:33 AM
Modified 006 curve
Just had a reply from 123 Ignition. The curve in position D based on a graph from The Alfa Romeo DOHC Engine High Performance Manual by Jim Kartalamakis is just a simple straight line.
It begins advancing at 1,000 rpm and reaches its maximum of 21 degrees at 4,000 rpm in a simple straight line.
No need for a graph on that one!
Hope that helps,
Richard Norris
Classic Alfa
UK
  #59 (permalink)
Old 12-11-2007, 12:54 PM
Max Banks's Avatar
Max Banks Max Banks is offline
Starting from how many degrees at 1000 rpm?! What happens after 4000 rpm, stays at 21 degrees?!
www.alfaholics.com
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
  #60 (permalink)
Old 12-11-2007, 01:11 PM
Alfajay's Avatar
Alfajay Alfajay is offline
Max:
In the 2nd edition of Jim Kartalamakis' book, he outlines how to modify a late Bosch distributor so that it advances only 22 degrees. He recommends setting the static advance at 10 - 14 degrees, yeilding a maximum total advance of 32 to 36 degrees. The curve shown in his book (see pages 82 - 83) goes flat at 4,000 crankshaft rpm. So, the answer to your second question is "yes".
I will admit that total maximum advance settings in the low 30's sound low to me, but that's what Jim K. is advocating.
'63 Guilia spider
