Old 04-20-2007, 02:15 PM
roller roller is offline
ingram high performance spica pumps?
anyone out there with a 1750 outfitted with wes ingram's
performance street remapped spica injection pump & upgraded cams?
i'm interested to know how this affects the qualities of the engine.
my understanding is that i'd get a broader rev range, but that i might not
retain the low-end torque that my stock set has.
any wisdom out there?
thanks, john
1969 Alfa Romeo GTV Series1 U.S. Spec.
Old 04-20-2007, 03:41 PM
genericwood's Avatar
genericwood genericwood is offline
John, the modified pump will not have value unless your engine has significant performance modifications. With really aggressive cams, oversize valves and good porting, the stock pump doesn't work well. Wes' modified pump will. I have one on my hot 2L street engine and am very happy with it. This engine has oversize intake valves, 12mm long duration intake cams and 10:1 pistons. With Wes' pump, it idles at an only slightly lumpy 700rpm, pulls strongly at low revs and pulls to 7000rpm.
You will gain the ability to take advantage of your mods at higher revs, and shouldn't lose anything at the lower end as a result of the pump changes. Of course the hot cams that caused you to get a modified pump will often hurt the lower end. But the pump itself won't.
Erik
Old 04-20-2007, 04:29 PM
great info, erik.
thanks a ton.
john
Old 04-20-2007, 04:38 PM
George Willet George Willet is offline
Senior member
What Eric said: DITTO.
George Willet
willet@q.com 520-374-2220: please do not use PM, email me direct, saves us both time.
Note: I prefer to offer parts to the AlfaBB members first, and eBay second.
THESE are the good old days!
There are no easy answers to complex problems.
Old 04-20-2007, 05:07 PM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
Originally Posted by genericwood View Post
... This engine has ..., 12mm long duration intake cams ...
Erik
Erik,
Are these custom cams, or C&B cams?
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 04-20-2007, 05:56 PM
I guess you would call them semi-custom. On this particular head, Wes supplied the cams. I have the specs somewhere..... Then he matched the pump to the cams and ports.
Erik
