Old 03-31-2007, 04:31 PM
Sneds 67 GT's Avatar
Sneds 67 GT Sneds 67 GT is offline
Off road Alfa
Just thought I would enjoy the GT today, with my usual "spirited" jaunt through the countryside. Well, on "turn 4" of my usual river road journey, the rear end snapped around faster than I could stay on the steering- the car bounced backwards about 40 MPH, through a plowed field, and the car came to rest about 75 feet into the field. Luckily, there is little to no ditch, and I was able to drive the car out of the field, a little muddy. No vibrations and the car tracked like nothing had happened, very strait. Other than crappin' my britches, my question is if I hurt the motor. During the brief off road, my foot was as hard on the gas as the brake, as I was in a panic to get it stopped. I flashed a glance at the tach, I believe it was about pegged, I have no idea what RPM I hit, but I have never heard it scream like that before. Alot was happening in those brief few seconds!!!
What can I expect if I "spun" the motor to fast? Would I already have problems, or is this something that may take a bit to surface. The oil was at temp, and the rev was for a brief second or two. Everything seems fine so far, drove home about 7 miles or so with no abnormal sounds or vibrations.
Sprayed some mud off from under the car, there seems to be no damage, changed my pants and had a drink. At least now I know thats a second gear corner.
Todd S.
84 Spider Veloce
67 Giulia Sprint GT Veloce
Old 04-01-2007, 05:36 AM
genericwood's Avatar
genericwood genericwood is offline
You can rest easily. You probably did no damage except to your underwear! Your over-rev situation is akin to a badly missed shift. The most likely damage to occur would have been a valve floating and contacting a piston. If that were the case, you would know it by now. The lower end will normally handle some of this abuse, assuming it has oil pressure. Sounds like you did no damage.
Snap oversteer is rather unusual in a stock GTV. Did you drop the throttle right as you entered the turn. That will bring the rear around. If it wasn't a driver mistake, I would very carefully inspect your rear suspension (and tires) before driving hard again.
Erik
Old 04-01-2007, 06:49 AM
py105's Avatar
py105 py105 is offline
Will it ever... Often with disastrous consequences...
Old 04-01-2007, 08:44 AM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
When you do serious damage, you can tell right away. You can stress metal by using it hard and also break it, but it doesn't sound like you have fatigued anything to the point of failure. All the internal components do have limits (which is why a stock engine has a redline of 6300 rpm, and racing engines use components made of materials that will tolerate much higher revs) so you are wise to be aware of that. I'm sure that in your case, you've caused some wear, but this doesn't mean that you've damaged the engine components. Just don't do it again!
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 04-01-2007, 09:58 AM
I'm not certain what happened. I take that corner the same speed most of the time, I think I felt a little more of a bump (may have cut it a bit short) felt the rear raise just a bit but no warning of it snapping around, until I was backwards. Took the car out this morning, felt great, no problems. I will change the oil this week, hope I don't find anything in there. The road I use to shake the cars out is the only curvy road in the area, very lightly traveled, and fun. Thank goodness it's very forgiving in most corners, the one I lost it on is very flat with no ditch.
Thanks for the reply, my foot was against the throttle as it was on the brake, making for a big rev.
Todd S.
84 Spider Veloce
Old 04-01-2007, 10:38 AM
60sRacer 60sRacer is offline
Snap oversteer is rather unusual in a stock GTV. Did you drop the throttle right as you entered the turn. That will bring the rear around. Erik
Stock, almost all cars understeer because of this problem- a gift from Ralph Nader and the Corvair lawsuits.
But the easiest way to make a car feel more 'sporty' is to make it oversteer a bit by changing the springs and sway bars, etc (like we all do!!) This also makes it vulnerable to "trailing throttle" oversteer. It takes training to enter a corner a bit too fast and RESIST the temptation to lift the throttle. Turn a bit harder and mash the throttle is the correct but very scary response (this will make the car plow or understeer as it loads the outside front tire and sometimes lifts the inside rear).
Even fancier, the SCAB rallye drivers invented the use of BOTH throttle and brake at the same time to carefully balance tire slip angles at both ends. This is why you see these cars blasting across the country side so accurately and so fast (and occasionally crashing so bad...). The technique is also used by the latest fad of "drifters" racing.
But as Carrol Shelby once said: "The only difference between over-steering and under steering is which end goes through the fence when you are dirving too fast already."
Pushing anywhere near the limit on public roads is really dangerous - conditions are not reliable, and change a lot. Imagine a motorcycle pulled off the corner for a minute and scattered dirt from the shoulder on leaving - you suddenly are heading for a dry-weather ice patch!!
Join the group of guys at a X-cross or a TT. It's safer and a lot more fun!
Oops! add "and gals...."
Robert
Old 04-01-2007, 05:01 PM
Robert, your comment about the motorcycle putting dirt on the road reminded me of the time I was out for a pleasure drive in the Giulietta. It was on the only somewhat curvy road I ever found in the far western Chicago suburbs. There was a tight decreasing radius corner with no trees or anything to block vision of the corner exit. On the straight just before the corner, I was passed by 3 very fast crotch rockets. As I saw them enter the corner, I hoped they knew what they were in for. None of them went down, but all 3 went at least 100 yards into the corn field on the outside of the corner. They were lucky it was early June and the corn was still short!
You know, with the Corvair, I would rather back one into a wall hard than hit the wall with the front. They are much stronger in the rear. Guess Nader never thought of that. We used to tow our Giulietta race car to the track when I was a kid behind a '65 Corsa.
Erik
Old 04-01-2007, 05:42 PM
Erik,
The strangest thing about the Nadar/Corvair issue is that the Porche 1600 Super of the same era had EXACTLY the same "Swing Axle" rear suspension, and was one of the great sports cars of the time BECAUSE of it - one of the earliest independent suspensions in sports cars.....
Robert
Old 04-01-2007, 06:20 PM
txcoyote's Avatar
txcoyote txcoyote is offline
Nader, maybe he'll run for President again!
Russ Rosenberg
87 TVR 280i
71 Triumph Stag
1974 GTV 2000
68 Jaguar E-Type
67 Ford F250
Old 04-02-2007, 09:57 AM
alfazagato alfazagato is offline
I am not certain I follow what happened. If you were braking hard and your foot was also on the throttle, were you left foot braking or one foot covering the two pedals? If it was the latter I would not expect that the travel on the brake would be greater than the travel on the throttle so, despite what it sounded like I would have thought you were not causing damage. You can put your mind at rest by re-creating the positions of the pedals, and see what additional motion there is left on the throttle pedal. Better luck next time!
Stuart
Old 04-02-2007, 02:09 PM
I was wearing my jogging shoes, they are kinda wide, and as I attempted to brake, my foot was half on the brake, half on the throttle, I guess. I think I managed to clutch, I really can't remember. All I know is I hit enough throttle to really rev the motor, not sure how much brake I had in it. I drove the car to work today, all seemed ok. Size 11 Saucony jogging shoes are not the best to drive in, for me, and I also have learned that lesson. It's even worse for me in my Spider, I have to be careful of what shoes I wear when I drive in it. I think now that I may have been on the gas/brake to cause the slide, I don't know for certain.
Todd S.
84 Spider Veloce
Old 04-02-2007, 02:55 PM
oops-a-daisy!
Stuart
Old 04-02-2007, 04:35 PM
PSk PSk is offline
If you really pegged the rev-counter, which I do not think you did , then you may have cracked something like the crank.
Many, many years ago I missed a third to fourth shift on my race car during a test session. Thus my motor was at 8500 rpm and I got neutral instead of fourth and thus she spun really hard, indicating way passed (and I mean way passed) the top value of 10,000 rpm ... unfortunately my rev-limiter did nothing . I estimate that this little Sud motor hit atleast 12,000 rpm!!! This was a 200hp 1600cc full race Sud motor.
The motor ran fine and I finished the test day. We checked all valve clearances and everything was fine. Next race meet the crank broke ... at ofcourse 8500-9000 rpm and destroyed just about everything . We believe the huge rev cracked the crank ...
Note as alfazagato said if you had your foot on the brake as well then she may have free revved, but very unlikely to be as bad as mine as I had my foot planted to the floor ... until my brain kicked in and I lifted.
Best
