'67 GTV 1600 vs. '67 Super's 1600
I'm in the process of restoring my '67 Giulia Super and discovered that the block (AR00536) is from either a GTV or a Boattail.
I know that the Super specs state about a HP difference of approx. (13 hp) less. The GTV:125 @ 6000 rpm vs. the Super's: 112 @ 5500 rpm. Torque was 115 @ 2800 for the GTV vs. 110 @ 2900 for the Super. Gearing was identical for both.
The questions are: did the GTV have different cams, does the block (crank)make a difference or was it just a matter of advancing the timing. ?
Interestingly enough, the Giulia SS (1600) developed 129 hp @ 6500 rpm with Veloce cams. Which again makes you wonder how a car with more hp (and Veloce Cams) than the GTV can be 2.5 sec. slower to 60 mph?
L'Alfista
www.lskarchitects.com
'67 Giulia Super
'69 1750 Spider Velove
'71 1750 GT Veloce
'74 2000 Spider Veloce
'81 GTV6
