07-27-2007, 07:58 PM
If you have a GT then you know what these are. You also know they get RUUUSTY! At times, sourcing them can be a real challenge too. So, you in up repairing them. I thought it might be helpful to folks see how that is done.
All of the weather stripping rails were put in the blast cabinet and the paint was removed.
Once cleaned the level of damage was clearly bad...
The sections that just had pinhole damage we used copper backed plug weld pliers and welded them up.
But the sections that had far worst damage, we made center sections for it.
The repair section....
After that, metal etch primer then black epoxy paint.
_________________________
1967 GT sprint Veloce
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
1959 Lancia Flaminia GT
1 very understanding wife!
http://www.vintagecustoms.net
07-28-2007, 04:13 AM
akitaman i'd go with aluminium ones right away as these are an important part in weatherstripping
07-28-2007, 09:00 AM
Hi GTV-GR, I would agree the aluminum units that are available in Europe is the way to go. But we only needed to fix three of the ten. If we need to fix half or more, then we would have called Max. BTW, how are things going with your motor issues?
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
07-28-2007, 05:55 PM
...in the Garage...
Neat repair Daron....do you MIG weld these or oxyacetylene weld?
08-08-2007, 12:46 PM
Missed the developments here.... air boxes.... they can work fine for 1600 as the size is not a problem. On our twin spark motors we really cannot get within 5BHP when using a cold air box.... we put it down to volumes - we just think you can't make them big enough to flow the volumes of air required, so you end up restricting the engine. As soon as we take the box off, the power comes back. We even tried home making some really big ones from aluminium and it still did not give the power of open trumpets or Pipercross single filter. Looks like you have having some fun with the channels there Daron!
www.alfaholics.com
1966 2.0 Sprint GT race car, 1967 T/S GTA Replica, 1965 FIA App.K 1600 GTA, 1965 1600 GTA Stradale RHD, 1965 1600 GTA Stradale LHD, 1966 1600 Giulia GTC, 1991 S4 Spider, 1967 1600 Duetto, 1999 2.0 916GTV (soon to be sold!) and now replaced with 2002 3.0 V6 24v 916 GTV
08-08-2007, 02:29 PM
I'm pretty sure it healed Daron, one never knows with those Alfas.
I'm having some body issues though...so when are you coming to Greece?
04-21-2008, 08:13 PM
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
04-22-2008, 05:02 AM
...a custom license plate light frame.
That is quite a target for SUV's!
I hope the owner has good luck when leaving it parked.
Alfista Sapien
04-22-2008, 10:44 AM
Daron -
Seeing the gas door delete pic reminded me that I had a question for you regarding body panel adhesive. In my case it concerns a small patch uf rust under the c pillar badge. Since I don't have access to a TIG and am not ready to remove my headliner, I was contemplating cutting out the area with the rust and making a patch with laps and gluing it in (laps on the inside of course). What is your general feeling about body work with adhesives instead of welding and is this specifically a reasonable plan?
Bill
1973 2000 GTV Blu Olandese
1971 Karmann Ghia Conv.
1982 Toyota FJ40
04-22-2008, 07:16 PM
Hi Bill. I have a 165 pound 7 month old puppy in my lap demanding that I play (I just got home). So if this sounds odd, it's because its in a rush. If you must do it this way use liquid metal and a fair amount of cavity wax. This is not a great long term deal but it will work.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
04-22-2008, 08:02 PM
Thanks, Daron. I guess maybe I'll just treat it and paint it as a stop gap until I'm ready to take it apart and do it right.
Bill
1982 Toyota FJ40
05-08-2008, 06:50 PM
So the front of the car is getting a GTA mesh grill set-up. But in this case we are resetting the grill to be deep set to the opening.
Here you can see the 1-1/2 inch flange on the top plate.
And here the bottom plate
And here the grill was test fitted
And here with the other trim pieces
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
