05-15-2007, 08:56 AM
Try 1400 Kit
Originally Posted by 1166
I have a 1300 jr that I drove for a while (15K miles) with the 1300 and I LOVED it. I drove that car faster than any other car (all Alfas) I owned. It really liked to be around 4500 rpm on the highway (all the time). I busted some ring lands (probably from revving it to 8K all the time) and I installed a rebuilt 1750 with a 1300 flywheel. It SHOULD have been really nice but I could NEVER enjoy it the same. The power was nice but I always thought the cars was missing something. It seemed to buzzy on the highway (.85 fifth, good for racing or a 1300). The 1300 NEVER sounds strained in any way and it is a lot of fun because you have to plan your actions and execute passing maneuvers with great precision to overtake cars safely. You also get to rev the snot out of it to go 'fast' and even then you are not breaking the limit (as badly as a 2L would anyways). It occasionally is a bummer to NOT be able to pass thinking '... if I only had another 30hp I could easily do this...', but you get over it pretty quickly. Oh yeah, I sold the 1750 (I put on 6-8K miles) and put a 1300 back into my car.
Recently had to rebuild a motor, and looked at a choice between a 2L transplant or staying with the 1300 core, in a Nuova Super. I opted to stay with the 1300, but take advantage of Centerline's Wiseco pistoned, 1400cc kit. It's marvelous. Just a bit more grunt, but spins just like the 1300. Smooth as glass, loves to run through the revs. I'm running a long duration cam with right at 10mm lift, and tighter valve clearances to initiate the valve sooner... sort of like an add'l 0.5mm of lift. The blaster coil and Personix ignition finish things off. Though I'm missing some of the off-the-line punch of a 2L, the trade-off in smooth running at the higher revs is worth it to me.
I'm actually thinking about building up a bigger bored, shorter stroked motor in the 1400 cc range for another car in my future.
I've become a big fan of the little motor.
Ish-Man
75 Nuova Super 1300
05-15-2007, 09:04 AM
As usual fantastic to see it come together.
I am so greatfull that you take so much time to show us your work, I am sure everyone appreciates it.
Looking forward to seeing the motor being built hope it is as well documented as the rest of the build
PS What is your usual source of replacement panels ?
1973 GTV
2007 Chevrolet Caprice SS (6 litre V8)
Previous Cars-82 GTV-84 90-82 Sud
05-15-2007, 07:11 PM
Hi Geofd! Thanks for the supportive words. I use folks here in the states for common items. But for panels and other parts I use Alfaholics.com and classicalfa.com in england. The panels they provide me are second to none.
BTW, we put the spare tire tub in this the other day.
_________________________
1967 GT sprint Veloce
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
1959 Lancia Flaminia GT
1 very understanding wife!
http://www.vintagecustoms.net
05-16-2007, 11:58 AM
hi Daron, i can agree with you on the matter of parts from both Max and Richard Norris, both good companies with a passion for the cars, Also handy living so near i can pop round and pick the things up i need. When i'm next over on your side on the water i would like to pop in. Keep up the great photo stories
Andy
'74 Le Mans Blue, London
05-16-2007, 05:24 PM
Are you going to add the 2 drain holes? ...
05-16-2007, 06:25 PM
Hi Andy. Anytime your in the area, your more then welcome to come by. We are only 15 minutes from Seattle.
Hi Pete. Yes the drain holes AND the weep hole will be cut in. You can see that in the spider thread I have.
It had occurred to me this morning that if a monster motor is going to be stuffed in the car, then I should reinforce the tranny mounts. So I doubled up on the perimeter welds and plated behind them.
And we finished the floors too:
We'll clean the welds and texture the bottom shortly.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
05-18-2007, 09:23 PM
I finished the repairs to the trunk today. With that said it was time to texture it. Were not going to cut the drain plug holes but the weep hole was made. Once the ATL fuel cell sits in here this will look great!
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
05-19-2007, 08:07 AM
Hey Ish-Man, glad to hear your good words about the 1300 engine. The one gleaming point about my junior appears to be the engine. According to the previous owner, it had a complete overhaul in 1985, by a German Tech-Alfa Specialist, just a few hundred miles before it went into storage. We took the time to flush and roll it over alot before firing the engine and it is smooth as silk and not a hint of smoke. So, I will really be looking forward to unwinding this thing on some mountain roads.
Tim
'67 GSGTV-Q (1975)
'69 GT 1300 Junior (current)
'66 Mustang Coupe (current)
06-13-2007, 07:58 PM
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
06-14-2007, 08:20 PM
As we are waiting for the replacement front clip to arrive, we started in on some of the repairs needed at the radiator support section. Heres a couple of replacement parts we will be installing. We made the sections from templates we keep on hand. As we find ourselves making part more then once we make a template to save the customers time and money.
Here Steven is cleaning the surface for weld through priming to be applied.
To make the install easier, we flipped the car over.
Steven is starting out by MIG welding the weep edge to the radiator cross member.
Once it was welded Steven used the resistance welder to seam it to the factory fold.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
06-15-2007, 07:41 PM
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
06-22-2007, 11:08 PM
Well the new step nose front clip arrived today.
And here it is next to the heavy damaged old unit. As you can see the head light frames don't come with it the new unit.
If you elect to replace the front clip on your step nose make sure to leave the top sub frame in place. It's important for hood alignment reasons.
And a test fitted front clip.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
06-23-2007, 01:29 AM
Is this a remanufactured aftermarket front clip?
If so that is crazy great news!
James Hochmuth
1970 GTjr
2000 Lotus Elise 111S
06-23-2007, 08:55 AM
Yes, it is a aftermarket front clip.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
06-26-2007, 07:58 PM
Okay, this nose clip effort is not one I would suggest for the hobbyist. It takes time and lots of pre thought. As I said before, if you do try it, make sure to leave the hinge frame in place. The Hood could be way off alignment if the frame is not put back exactly where it was.
In this photo, I confirmed the hood location after the nose was installed.
The car is heading over to Group Two to have the suspension upgraded on Thursday. So we got the engine bay in color so they can do the install .
The photo is with my phone camera so the color is hard to see. It's Dutch blue.
1969 GTV
1967 Giulia Super
1967 Duetto
1972 Spider
