OK, now seems a good time to bring this up. I've been following with much interest the posts re. South African built Alfas in the History Forum and recently the auto GTV thread in the Picture Room Forum. My 1975 GTV automatic is part way thru a fairly major rebuild including panel repair, paint (twice so far
don't ask), trim etc. and I performed a manual transmission transplant courtesy
of a donor car.
I understand from previously posted info that these RHD GTV autos were assembled in SA using CKD kits combined with locally sourced paint, trim etc. I realize that these cars are probably of limited interest to you guys in the States (since they were never sold there) but I would be interested in documenting the various differences between these cars and the RHD export Italian assembled cars. Some items I've noticed so far:
1. All the cars I've seen so far are either Silver or White with off white trim in the usual narrow pleated style but the doortrims are plain vinyl (no diagonal heatwelded seams) with a stainless trim strip towards the top and bottom of the door.
2. The headliner is plain off white vinyl and not the usual snake bite material.
3. Carpet (black) is plain cut pile not the usual corded loop pile stuff.
4. The centre console is obviously a different style to suit the floor mount shifter for the 3 speed ZF auto trans.
5. The rear window lacks the heating wires and has a blanking plug in the dash where the switch should be however the car is fitted with the correct wiring loom and relay for operation.
6. The side and rear glass has no SICURSIV logo usually found on the Italian built cars. Was this locally sourced too?
7. The drivers seat on my car was biased so far to the RH side that the door was difficult to close because the armrest fouled the seat backrest and had been like that since new! I've since moved the floor mounts 2-3 inches towards the trans tunnel in the interests of driver comfort
8. The diff ratio is incredibly tall which only became apparent after fitting the manual trans. Fourth gear in my car is now the equivalent of fifth in most others!
The bit I don't get is why it seems the paint/rim combo was so limited. Also, were these auto cars sold in the UK and other parts of Asia? If anyone can provide any more info please feel free to join in.
