Both the front timing cover and the sump can be removed with the engine in situ but it isn't easy.
For the front timing cover you need to remove the head, the pulley and fan and therefore also the radiator for access but you already drained the fluids to remove the head. Then the sump (hey!) and probably a few other bits and bobs I have forgotten. Quite an undertaking.
The sump
can be removed with engine in situ but you need patience and some small fingers to reach some of the bolts above the crossmember. Access can be helped by losening the engine mounts and carefully jacking up the engine.
Engine out begins to sound like an easier proposition all of a sudden, he?
