I would get at least a 6" rim for the 205. Although you can fit a 205 on a 5.5" wheel, the tire will exhibit much more sidewall flex than if mounted on a wider rim. The 5.5" rim was designed for the original tubeless 155 and 165 sizes, and although a 185/70 will work, a 6" rim is the appropriate size for the 185 section width.
By the way, there are other tires in 185/70-14 sizing. Are you stuck on Yokohama for any particular reason? The AVS ES100 tire seems to be a very good tire and I am also considering putting those (205/60-14 size) on my '69 Spider.
Cheers,
Cheers,
Alex Csank
Chair, Alfa Century 2010 - The AROC USA ALFA Centennial Convention
E-mail: alfaromeodriveralex@gmail.com or alfacentury2010@gmail.com
Mobile: (757) 636-9513
82 Spider Veloce (Desideria - Kathleen's)
84 GTV6 Maratona (Mona - resto project)
88 Milano Verde (Trogdor The Burninator)
"My name is Alex and I am an Alfaholic."
Alfisti are always welcome in our home!
