Old 06-24-2005, 08:58 AM
series1gtv's Avatar
series1gtv series1gtv is offline
Electronic ignition options
Hey Alfisti, I am currently looking to buy an electronic ignition system for my 1969GTV. The engine is stock with spica injection.I have a couple of questions about these electronic systems.
1. What is the preferred way to trigger I have seen magnetic and optical systems what is the better way to go?
2. The systems I'm looking at are Centerline's ID405 and ID455 and IAP's RML performance ignition. Does anyone here have experience with any of these? The centerline systems are magnetic and the RML is optical.
Thank you for your help
Jeff
La Voce
1969 GTV
1961 Giulietta Berlina
Old 06-24-2005, 10:09 AM
SILVERBULLET SILVERBULLET is offline
on my 74 spica gtv i have the rml 4101 ignition. in hindsight, (after listening to what john m has to say on the subject because he really knows his stuff) i probably would go with the 4101r system instead. you get a better mutispark system plus the magnecore wires. having said that, the 4101 system was easy to install and the car starts and runs with the ease and reliability of a toyota. for a plug and play system, i highly recommend it. and if you have a question, the rml guys are great to deal with. but i'm sure the centerline one is just as good and easy to install. electronic is the way to go...no points to deal with rids the car of the whole tuning issue as the points wear.
John D
74 gtv
Old 06-26-2005, 07:42 AM
Wil Painter's Avatar
Wil Painter Wil Painter is offline
Jeff:
As is so often the case, the answer to your question depends in part on what your intended use and goals are. You say you are still stock. I’ll assume that means you’re principally driving on the street.
The Centerline 405 will give you the benefits of no points/condenser to change, a new distributor with a good advance curve, and long-term stable ignition performance. At moderate performance levels, Gary Valant convinced me many years ago that once you achieved these benefits, there was no more HP to be gained with ignition systems, assuming a car that is otherwise operating to specification (mixture, compression, etc., i.e. a sound, tuned motor). It also is appears stock. I have one in my vintage racecar, as I run fairly conservative engine speeds and liked the original, stock look. The 405 will be a quantum leap in reliability and basic performance for you.
Modern ignitions have come a long way since my discussions with Gary. They offer long duration, multi-spark capabilities (in most cases below 3000 rpm), rev limiters, and the ability to fire engines under all sorts of difficult conditions, so my thoughts may be somewhat dated (of course, so is my body these days ). I have no direct experience with either the 455 or the RML systems. Centerline is a top flight vendor, and RML is used by many racers. As John says, they also have a great reputation for service. In terms of reputation and service, I don’t see how you could go wrong with either one. Perhaps someone else can offer a more sophisticated analysis of the cost/benefit ratios for your intended use.
Good Luck
Wil Painter
66 GTV (Watkins Glen Bound)
94 164LS (for sale to pay for the Glen)
78 Suburban (to get me there and back)
