I aaasume the car you refer to is the '67 1300 in your signature. There is no oil temp guage in this car is there? On most of the carb-vintage alfas, the oil pressure sender is at the rear of the block under the carb manifold(1); the water temp sender is at the front of the carb manifold, on top above the distributor(2). The oil pressure idiot light switch is on the oil filter housing(3), and for later (1975+) alfas the water temp idiot light sender is on the head screwed into one of the water jacket plugs(4). That's all the senders.
Robert
