Old 04-09-2005, 07:59 PM
jpv's Avatar
jpv jpv is offline
equal lenght headers
anyone knows any equal lenght exhaust headers for a 69'GT Junior LHD with floor pedals?
Joćo Vale
1969 Alfa Romeo GT 1300 Junior
1972 Alfa Romeo 2000 GT Veloce
1976 Porsche 924
1991 Mazda Miata MX5
Old 04-09-2005, 08:17 PM
JoeCab's Avatar
JoeCab JoeCab is online now
Paul Spruell's Tri-Y headers come to mind. Great for the track, not so good for the street.
http://www.paulspruell.com/motorspor...raceparts.html
Joe
Old 04-09-2005, 08:21 PM
Wil Painter's Avatar
Wil Painter Wil Painter is offline
I'm very happy with my Paul Spruell headers (vintage racing application, not street). I have a (1972) 2L in a LHD 1966 GTV with 1969 floor pedals. My engine may be taller than yours, I would correspond with Paul to confirm fitment. http://www.paulspruell.com/
Good Luck,
Wil Painter
Old 04-10-2005, 06:14 AM
jpv's Avatar
jpv jpv is offline
no problem there Wil, it's also got a 2 liter engine.
But it's more for a street/track day aplication... The Paul Spruell doesn't work well for street? why? emissions?
Joćo Vale
1976 Porsche 924
Old 04-10-2005, 11:36 AM
JoeCab's Avatar
No, they produce a very high, peaky powerband. They were never intended as anything other than a race header.
I have GTA headers (well, a complete GTA repro system) on my 2 liter GTV and they are a great street/track compromise. They take a bit of fiddling to make them work with the taller 2 liter but well worth it, IMO. An added bonus is there are no slip fit joints at all in the system.
Joe
Old 04-10-2005, 11:50 AM
jpv's Avatar
jpv jpv is offline
what did you do to make them fit?
Are they equal lenght? never saw one of those, anyone has pictures?
Is that the same header ClassicAlfa sells?
http://www.classicalfa.com/shop/category14_1.htm
Thanks for the info!
Joćo Vale
1976 Porsche 924
Old 04-10-2005, 11:59 AM
JoeCab's Avatar
We have the GTA exhausts in stock at Centerline - it looks like the same system available at Classic Alfa. IMASAF makes a great product. We also have a header specifically for a 2 liter that mates to the standard GTV Exhaust.
http://www.centerlinealfa.com/new/headers.html
We had to do 2 things to make the GTA header fit a 2 liter:
1) Space the headers away from the block with 1/2" spacers (we keep them in stock)
2) Heat and bend the header pipe where it curves under the chassis. This is due to the 2" difference in height between a 1600 and a 2 liter. You may not need to bend it as much as I did if you have floor pedals.
Joe
Top Photo=GTA Repro Headers Bottom Photo=Centerline 2 Liter Headers
Old 04-10-2005, 12:21 PM
Gary Williams's Avatar
Gary Williams Gary Williams is offline
I have the Spruell headers on a '67 GTV with high performance 2L engine. It's mainly an enthusiastically-driven street car, though the head has big valves and is ported and polished, I'm using DCOE 45's, hot cams, an aluminum flywheel, high compression pistons, etc. The specs are at www.greend.com.
Friends told me the headers would be a waste of money, but I've always wanted cool looking headers, so I bought them anyway. In short, they were a waste of money and the cause of much trouble. My friends really were friends; I just didn't listen.
The headers were not welded correctly when manufactured so we could not bolt them in. It took weeks to get them repaired. While they were at Spruell's I had plenty of time to break in the new engine with the stock cast iron headers.
Now, having run the same engine with stock and Spruell headers, I find:
1. No discernable power increase. I shift at 7,000 rpm, but don't sustain that engine speed. Maybe that's why these headers don't seem
to make a difference.
2. The Spruell headers are noisier than stock.
3. They are more prone to cracking and working loose than stock headers, and are more difficult to seal against the head than stock headers.
4. The Spruell headers generate tremendous heat in the engine compartment. That's great if you want to bake a chicken while you drive, but I've already had to replace the brake master and switch to expensive high temp brake fluid because of that heat. And my new speedo cable has had the outer covering burned off by the heat. I'm now using insulation around brake lines, steering box, and speedo cable to try and control the heat -- all for no noticeable gain in power.
Why do I leave them on? Because to take them off means more money at the muffler shop ... and I'm stubborn. Having spent so much time and money to put them on -- not to mention the emotional energy expended when dealing with the manufacturer -- I'm loathe to give up easily.
Gary W.
Old 04-10-2005, 12:31 PM
universible's Avatar
universible universible is offline
Talk your son into coming over to remove them...then ebay!
Ted
Current:
74 GTV
Former :
88 Milano Verde
78 Alfetta Sedan
87 Milano Verde
70 GT Jr. 1300
[URL=http://www.flickr.com/groups/scuderiano/]Scuderia Non Originale Flickr Group[/URL]
Old 04-10-2005, 12:38 PM
JoeCab's Avatar
Gary, not to make light of your travails with the Spruell Headers, but I once cooked a nice dish of potatoes, onions, and garlic on my headers on a club rally. We were having a picnic lunch, so I threw them in the engine compartment about 45 minutes before lunch in one of those heavy duty foil barbecue bags, and they were nice and toasty when we got to our stop.
Back to your headers - at the least they (along with the rest of your car) LOOK amazing!
Joe
Old 04-10-2005, 01:47 PM
genericwood's Avatar
genericwood genericwood is offline
Gary, I'd be happy to trade you a nice stock manifold for your Spruell headers. I'll even pay to have a muffler shop make the swap
Seriously, I doubt any of us are sensitive enough to power changes to be able to recognize anything under a 5% change. I'm told you can get quite a bit of change just with temperature and humidity. The only way to know for sure is to compare dyno runs. But that gets as expensive as the headers!
Erik
Gary W.
Old 04-10-2005, 04:06 PM
Erik
I agree that's it's difficult to tell minor power changes. My point is that any difference between the stock and Spruell headers is minor, especially in a street application. For my use, that makes the headers a lot more trouble than they're worth, especially given what I had to go through to get the fit right. That's a whole other story I won't get into here.
Now I've got the bloomin' things set up, complete with $4.50 nuts to hold them on (that's each), I'm not going to change until they fall off. I'll let the BB know when that happens. Until then, the perfectly good cast iron headers from my 1600 engine wait patiently with other original bits and pieces that are no longer on the car.
GW
Old 04-10-2005, 06:02 PM
Gary, clearly the trouble you put into the headers and everything else (i.e. air box!) was worth it. Your engine looks great!
Erik
  #14 (permalink)
Old 04-11-2005, 11:20 PM
Biscione's Avatar
Biscione Biscione is offline
Gary,
The next Magnaflow Dyno Day scheduled in October should be a good opportunity to get some hp data......hope you can make it.
Biscione
  #15 (permalink)
Old 04-12-2005, 10:14 AM
I look forward to hearing when that dyno date will be. If the engine still isn't up to where it should be this time around, can I apply a fisherman's fudge factor when talking about the engine's horsepower?
GW
