#16 (permalink)
Old 09-23-2006, 05:17 AM
davbert davbert is offline
Joe,
I couldnt find your spacers in the catalog... is 1/2" the only size they come in?
Do you have to change to longer head studs for the increase thickness?
davbert
Originally Posted by JoeCab
We have the GTA exhausts in stock at Centerline - it looks like the same system available at Classic Alfa. IMASAF makes a great product. We also have a header specifically for a 2 liter that mates to the standard GTV Exhaust.
http://www.centerlinealfa.com/new/headers.html
We had to do 2 things to make the GTA header fit a 2 liter:
1) Space the headers away from the block with 1/2" spacers (we keep them in stock)
2) Heat and bend the header pipe where it curves under the chassis. This is due to the 2" difference in height between a 1600 and a 2 liter. You may not need to bend it as much as I did if you have floor pedals.
Joe
Top Photo=GTA Repro Headers Bottom Photo=Centerline 2 Liter Headers
  #17 (permalink)
Old 09-24-2006, 07:05 AM
ddouglas77's Avatar
ddouglas77 ddouglas77 is offline
Send a message via MSN to ddouglas77
A quick remark on the heat generated from the headers and then switching to hi temp brake fluid...Jet Hot ceramic coats even custom made headers, their silver finish is very chrome like (I got a picture of Headman Hustler Headers on my 74 Camaro), that would stop brake cooking and severly reduce under hood temps including fading the paint of the hood.
  #18 (permalink)
Old 09-24-2006, 11:32 AM
Gary Williams's Avatar
Gary Williams Gary Williams is offline
If this is relating back to what I wrote last year, I paid extra to have PS put a "space shuttle" coating on the headers that was supposed to be better than Jet Hot.
Gary Williams
Washington State
'67 GTV
  #19 (permalink)
Old 09-24-2006, 12:03 PM
ddouglas77's Avatar
Yes, this was about that posting-funny though, jet hot does nasa's coatings...
  #20 (permalink)
Old 09-24-2006, 02:20 PM
RossoGTV4Me's Avatar
RossoGTV4Me RossoGTV4Me is offline
GTA Header for a 2L
Joe,
Do the GTA headers offer more HP then the 2L headers you sell. I assume the GTA headers are exact replicas of the original GTA headers? Are ther GTA headers of larger diameter then the 2L ones Centerline selsl and stock 2L headers? What makes the GTA headers superior for performance over the 2L headers? Just curious as the GTA headers were originally designed for a twinspark 1600 motor.I am assuming it is the flow design of the header? Are there any diffrences between the GTA headers Centerline cells and the IMASAF ones? I was just concerned with making them fit but it seems that you detailed what is needed to make it happen. I have a few questions.
In regards to the second step "2) Heat and bend the header pipe where it curves under the chassis. This is due to the 2" difference in height between a 1600 and a 2 liter." Question: Did you have this manderal bent or does it matter? Any instrcutions or insight to give a shop on how to do this correcty? Any detail of how much you had to bend this and if it is just minimal I assume it would have no efect on the headers performance? Will the header then bolt right up to the stock center exhaust?
I have a 2L that I am thinking of putting CB47 cams This was also a Auto Delta cam in the old performance cataloughe and was used in Gp1 spec cars racing in 1970-73 in the Euro.Championship. Same AR/AD part number 115.01.03.200.32 , this is the exact same profile as the old CB47 and somewhere between Shankle's 7L and 8L profiles. It came highly recomended. for a mild street upgrade.
Joe
-65" Sprint GT (GTA Replica Race Car Project)
-66" Sprint GT Veloce (Project)
-69" GTAm (Project)
-73" 2000 GTV (Orig. Owner)
-75" Alfetta GT (Rally/Street)
-75" Alfetta Berlina (Rally/Street)
-94" 164 Quadrifoglio (1/35 94" Q's imported to US) (Entertaining Offers) http://www.alfabb.com/bb/forums/164-...t-factory.html
