All pictures I've seen have the OVS on the inner fender in front of the air box. Mine is currently on the firewall behind the air box. This has the crankcase vent hose traveling over the airbox. I'm not much for oringinalilty, but I do like clean cable and hose routing.
Easy enough fix I though. Except he bung on the airbox for the OVS return faces aft. At some point the air box got a coat of black wrinkle. Did someone cut the bung off and weld in back on in a different orientation? I fail to see what this gains you. That's a lot of work, there has to be a good reason for it.
