stuck rings? - Alfa Romeo Bulletin Board & Forums
post #1 of 12 (permalink) Old 04-20-2017, 03:32 PM Thread Starter
stuck rings?
My 74 GTV has 4000+ on new pistons and rings, but it's burning oil (no smoke) and fouling plugs. Would it be beneficial to add Rislone to help things along. I've been running it at 5500 for a mile or two and maybe that'll help.
Dan H is offline
post #2 of 12 (permalink) Old 04-20-2017, 03:53 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Did you put in new valve guides when the pistons were replaced
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #3 of 12 (permalink) Old 04-21-2017, 03:03 AM
GTA R's Avatar
If you're sure it's burning oil, then there must be smoke.
As ARwrench says, if you didn't fit new valve stem oil seals, (and they're goosed), then you won't see smoke under acceleration or cruising, only when you back off and put your foot down again, usually from motorway speeds, ie if you're cruising at 70mph, back off, then accelerate again, you would see blue smoke at the back.
Very unlikely to be stuck rings if the engine has only done 4000 mls.
GTA R
Giulia Ti Super Rep yet to finish. BMW 2000 NK to Ti spec
GTA R is offline
post #4 of 12 (permalink) Old 04-21-2017, 12:21 PM
Alfajay's Avatar
Agree. And if the head wasn't rebuilt when the bottom end was done, then the increased compression of the new rings will draw oil past the valve guides and seals more aggressively.
I don't think Rislone will do anything for oil leakage past the guides and seals (though admittedly, I don't know a lot about the stuff).
'63 Guilia spider
Alfajay is offline
post #5 of 12 (permalink) Old 04-21-2017, 05:09 PM
Rule out an oil leak; the type that stops once you shut the car down.
tuttebenne is offline
post #6 of 12 (permalink) Old 04-22-2017, 06:28 AM
gigem75's Avatar
How much oil is it using? qt per X miles
Do you know what brand of rings were used?
Are the plugs oil fouled and look black and greasy?
Speaking without knowing any thing else, which is usually dangerous, the majority of motors that burn oil after a rebuild and have great compression numbers have rings that didn't seat and no additive can fix that. The only thing that can fix that and it's a case of the cure being worse than the disease is to extremely overheat the motor in hopes that the glaze is burned off the cylinder walls.
It's gotten to the point where most folks use Hastings rings because they seat so well. They just don't last 80,000 miles like other rings. That's generally not a problem with our Alfas. But using Hastings rings isn't really the answer. Good assembly technique is. Most motors that burn oil do so because the liners were not thoroughly cleaned before assembly. They have to pass the white glove test otherwise the honing grooves are full of microscopic crud that instantly turns to glaze on the cylinder wall as soon as the motor is fired up. I use WD40 on the piston and cylinder walls during assembly although the cylinders being clean is the real key to the rings seating right off the bat. Hope that helps.
currently
74 GTV restored daily driver
71 Berlina in resto
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
gigem75 is offline
post #7 of 12 (permalink) Old 04-22-2017, 10:05 AM Thread Starter
Thanks all for your input. The piston & ring rebuild was done by a very competent shop, as was the head work. Hastings rings were used. I was advised to run the heck out of it and that's what I'll try.
Dan H is offline
post #8 of 12 (permalink) Old 04-22-2017, 11:56 AM
gigem75's Avatar
If it has just started burning oil that is a whole new deal. The above only applies if it has been that way since day one.
currently
71 Berlina in resto
1972 GTV
1974 GTV
gigem75 is offline
post #9 of 12 (permalink) Old 04-22-2017, 02:31 PM
Go to the Hastings web site. Find the section on breaking in rings. They have a specific break in procedure. I used that on my 164S breaking and had no issues. Their tech dept maybe able to give you some advice on how to handle it now.
Richard2 is offline
post #10 of 12 (permalink) Old 04-23-2017, 11:30 AM
I have used Hasting rings for decades and always know that Alfa engines have large clearances for high RPM. I think that if you did not do a valve job then the oil is being burned from leaking through the exhaust valve guides. The intake valve guides use a seal, but there is no seal on the exhaust valve guides.
kuni123456 is offline
post #11 of 12 (permalink) Old Yesterday, 04:48 PM
I haven't had to disassemble the head on my car yet and therefore was unaware of that.
post #12 of 12 (permalink) Old Yesterday, 06:45 PM
gigem75's Avatar
There was a time when some builders were putting seals on exhaust guides, not so much now.
currently
71 Berlina in resto
1972 GTV
1974 GTV
gigem75 is offline
Replace with
